Question about Panasonic RR-930 Desktop Cassette Transcriber / Recorder
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The pedal works - it was tested on other unit. Otherwise, the unit rewinds, plays and fast forwards fine. Note, it also fast forwards okay when play is depressed. It just doesn't rewind with play down (if tape present).
    Champion:
    New Friend:
  • 231 Answers
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Posted on Apr 21, 2015
After erasing a tape I have a high pitched noise when I step on the foot pedal
If it works fine otherwise, I wouldn't spend much time worrying about it.
You might want to clean the heads and the capstan.
Jun 01, 2014 | Panasonic RR-930 Desktop Cassette...
Only used 2 months. rewind not working with the pedal but does work using the rewind button on the machine though sluggishly. works if I press down on the tape viewing cover. bought brand new on ebay a...
Could be a few problems. Sometimes the lube dries up on the solenoid so it is not engaging. Could have the rewind switch on the circuit board broken loose. possibly needs belts as well.
May 05, 2011 | Panasonic RR-930 Desktop Cassette...
Have a panasonic RR930 microcassette transcriber. Right now the foot pedal will not allow rewind though when I press the pedal I can hear it engage. I can, however, rewind right on the unit itself. ...
If neither rewind nor backspace work, the common problem would be that the solenoid grease has dried up and the solenoid is not retracting all the way. However, the track that the mechanism moves in also wears out, as well as the plastic rocker that depresses the rewind button where it engages the metal slide.
If backspace works but not rewind from the pedal then the problem is the pedal.
Mar 23, 2011 | Panasonic RR-930 Desktop Cassette...
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
When pausing and playing the tape screeches. Already tried another unit (same model) and changing out tapes. Still screetches.
Hello not sure if you referring to the audio when you realize foot control the unit does auto backspace and the short rewind is audible if this is not your problem the unit has a bad motor probably you can send it to repair to this place
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Nov 04, 2009 | Panasonic RR-930 Desktop Cassette...
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Apr 02, 2009 | Panasonic RR-930 Desktop Cassette...
Panasonic RR-930 Desktop Cassette Transcriber / Recorder Logo
403 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
