Question about Golf
I have a Yamaha golf cart Checked batteries , changed solenoid, tightened all wires The reverse beeps but won't move and forward do move either ! What would be he next step to troubleshoot
  • 6 Answers
SOURCE: electric golf cart, mash the pedal won't move
you have a broken belt .
Posted on Jun 03, 2009
SOURCE: complete wiring diagram for a 1990 36volts club car golf cart
http://cartaholics.com/forum/index.php?showtopic=1880&hl=green+wire
See if this helps. Good luck!!
Posted on Jun 30, 2009
shocktroop40
  • 155 Answers
SOURCE: ez-go golf cart press accelerator pedal and nothing happens
The first thing I would do is lift the seat and check the battery connections. Those batteries are notorious for corrosion at the terminals. Make sure every connection is clean and solid, as in no loose, corroded or frayed battery cables. Next, if the batteries check out, toggle the run/tow switch, also under the seat to make sure it is fully engaged into the run position, and finally check the forward/reverse lever to make sure the connections are clean and tight.
Posted on Aug 03, 2009
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
  • 100 Answers
SOURCE: need manual with the schematics for the wiring of
Need to know what year the club car is. No drawings are in the owner's manual and there are no free service manuals available.
But all is not lost, try buggiesunlimited website for downloadable wiring diagrams. If you still have problems I can maybe help lead you through some trouble shooting steps. email is arocles@bellsouth.net
Posted on Nov 08, 2009
Ezgo golf cart bucked then died. new batteries and solenoid. What happened?
Does solenoid still click? If it does then I would check the motor wires to see if they are still connected. If ok then I would check the forward/reverse switch assuming you have a Lever type mounted on the body of the cart.
Aug 31, 2017 | Golf
Yamaha electric golf cart 36v at motor but won't move reverse buzzer works has new batteries solenoid clicks Any ideas
I would make sure that the solenoid IS working even if it's clicking.
Make sure that the positive voltage is on the field side when it clicks.
Jun 26, 2017 | Golf
Should the solenoid have increasing voltage across the main terminals, 9.0vdc to 30vdc. Master switch in tow, key switch off.
My answer is I don't know regarding golf carts but generally a designer would arrange for a solenoid to be actuated by as constant a voltage as possible, especially if it is to be engaged for long periods. That is the only method to ensure consistent operation without danger of overheating. This is assuming the available voltage energises the soleniod.
I would expect the voltage across the main terminals would also be expected to be fairly constant so a predictable consistent performance can be provided over a long life.
You really need to consult a repair manual/wiring diagram. As a complete uninitiated golf cart layman I would expect the main solenoid switch to be switching the battery voltage which would then supply the speed and direction control board. I could be worng though!
May 02, 2016 | Cars & Trucks
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Club Car cart will not move forward---works fine in reverse
check the forward/reverse switch. Possibly a loose wire. Unhook the battery and go to each wire and verify it is connected properly. Then reconnect the battery.
Aug 15, 2015 | Golf
Yamaha Golf Cart won't start
did you leave the key on and kill the battery or a light or something double ck that battery , they will still light up the ignition and lights and ll but does not have enough to crank the starter , that is what is sounds like to me be put a jump on it or charge it and try again , when you turn on the ignition does the lights light up on the dash panal if so the batter is low
Mar 26, 2014 | Yamaha G-20 G20-g22 G-22 Golf Cart Tune Up...
Yamaha golf cart
Look under the seat for a pressure switch.
Mar 26, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Hello, I have a Yamaha 2001 Electric 36 volt Golf cart, i Bought it of a guy and it was Working Fine. I took it to a shop to check if everything was Good and check how to make it faster, They told me the...
Do you have a multimeter to check DC voltage ? You possibly could have the batteries hooked up wrong and not getting 36 VDC. Also did you replace with the same number (6) 6 volt batteries or three 12 volt ?
Mar 10, 2014 | Yamaha Motorcycles
My g14 yamaha electric golf wont go when we put it in forward or reverse and sometimes it makes a clicking noise when u depress the pedal
The clicking is the solenoid. If it won't move in either direction the speed controller is most likely defective. Hope this helps.
Jul 04, 2011 | 2007 Yamaha yBR 250
EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Apr 09, 2010 | 1993 Acura Vigor
Golf Logo
276 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
