Question about GE GDF520PGDBB 16-Place Settinand 4 Wash Cycles Full Console
How do I reset? It seems to be stuck. Water will not fill?
    Genius:
  • GE Master
  • 1,585 Answers
Check door catch
Posted on Apr 21, 2015
What can be wrong with my kenmore quietguard dishwasher if it does not fill with water
Most likely is is a stuck float or float switch. Next most likely possibility is a loose or broken wire going to the water fill valve. For some reason, mice seem to be attracted to this wire (usually 2 thin brown wires) - check for mouse droppings and look for chewed-through wires. Finally, if everything else seems okay, it is probably a bad water fill valve.
Sep 07, 2014 | Kenmore Dishwashers
Water is spraying from ice maker
This seems to be a popular problem. First I would unplug the fridge and plug it back in, sometimes it will reset the control and the solonoid for the water fill will stop.v if it does not stop that may be the water fill timer contacts are fused shut which means you need a new control board. I would also check the water basin for a float or water sensing probe. If they are dirty or damaged then it will not sense the water level and keep filling. I would also check the water fill valve to make sure it is not stuck open. If it is the board it might be easier to shut the water off and buy ice, they can be pricey. Good luck
Sep 07, 2012 | GE GSS25IFR Side by Side Refrigerator
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
WASHER WILL NOT STOP FILLING UP WITH WATER
Sounds like the pressure switch is stuck or the fill valve is stuck. If the pressure switch is not satisfied of the water level, it won't agitate, this is most likely cause. If it DOES agitate, then the fill valve is stuck. A kink in the pressure switch line or a pinhole can also cause this problem. The pressure switch is located in the console, it's white with a little clear hose going to it. It connects to the tub close to the bottom.
Mar 25, 2009 | Whirlpool 3.2 cu. ft. Washer
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Ice maker gets hot
    Sounds like a fault on the control board.
    It's supposed to go through a timed sequence of filling, freezing , warming and emptying.. It seems to have stuck in the (brief) warming stage.
    Try disconnecting and plug in again after 1/2 an hour.
    If it is still under warranty, get this sorted as a priority.
    If it will not reset, then a replacement control board is the only option.
    Jun 21, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
    Water fill light stuck on
    you say our fill the water light stay on lot they put a magnet in the water container fill it with water and gently tap the water container if the magnet stuck that should do it if it persite the magnet receiver under the cover is diffective normaly a few little tap do the trick
    thanks for using fixya
    pierre
    Feb 25, 2008 | Saeco Incanto Classic Espresso Machine
    Will not shut off at end of the drain cycle
    there should be a float behind the fill valve with a magnet in it which operates a reed switch. This switch keeps the pump running as long as the base has water in it or if the float is stuck on the up side (and makes the pump "think" that there's water in the base). Check this float to see if it's stuck and release it so it could tell the pump when to stop draining. Hope this solves your problem.
    Jan 31, 2006 | Bosch SHU9916 Dishwasher
    GE GDF520PGDBB 16-Place Settinand 4 Wash Cycles Full Console Logo
    74 people viewed this question
    Top GE Dishwashers Experts
    Mike
    jdthefixer
    Dan Webster
    Dan Webster
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
