Question about DeLonghi EC820.B Black Pump Espresso Coffee Machine
I have water squirting out around where my filter basket attaches the machine, and very little water runs throughout the filter basket. It also makes a buzzing sound. I have descaled, but no change?
    Top Expert:
  • DeLonghi Master
  • 10,875 Answers
Clean all parts with clr,calcium,lime,rust removal,make sure the hole isnt plugged
Posted on Apr 20, 2015
LOUD NOISES ARE HAPPENING
Unplug the machine from the electrical, then remove the unit from the basket and make sure the blades are clear of scrap paper.
Replace the unit and make sure it is facing in the correct direction and squirt, or lightly pour mineral oil (or machine oil, or something like WD-40) directly on the rollers and let it absorb into the remaining paper for a few minutes then try running the unit.
If that solves your problem, you should squirt a little lubricant onto the blades for every one hour of use.
Jul 10, 2014 | ACCO Brands Office Equipment & Supplies
I have the Krups 964 espresso maker; it is about 10 years old. Recently it began to pour water out and around the coffee basket holder at a fast pace, and it does not make expresso. I did remove the...
I don't know much about this unit, but there might be a rubber seal in head where the porta filter locks in to. It is possible that this seal is either damaged or just corrupted with grounds. Try cleaning it out and or checking the seal for damage.
Sep 10, 2011 | Coffee Makers & Espresso Machines
Coffee tastes funny. does machine need to be cleaned?
Yes, in this type of machine, put a little bit of vinegar and water in top and run a couple times through machine, with of course filter basket on, not with filter or coffee, and brew a couple times. Use 25percent to water ratio, do this twice then do it again, twice with only mineral water. Then make a pot normal, and let me know how coffee taste now. Thanks Mr Bean Man
Jun 09, 2011 | Bunn VPR Coffee Maker
Water is leaking from the side of the filter basket
The basket is probably not lined up any longer because of the pressure used to place the filter in the basket. Where you attach the basket to the machine, there are posts on the top and bottom. I had to put a small rubber rod behind the bottom post to make the top come back in line and that stopped the leak.
Sep 12, 2010 | DeLonghi Caffe Nabucco BCO70...
Had about a week. if i fill with 50 ounces of
Try taking the filter out, and turn the sprayhead off the unit. Put the basket back on, and try pouring clear water through the unit. If the water runs through fine, you either have a plugged sprayhead or are using too finely ground coffee. Look at the holes in the sprayhead, and make sure that none of the holes are plugged. If the basket still overflows, try using a drill bit to make the hole in the funnel a little larger. Good luck.
Mar 06, 2010 | Bunn BT10B Coffee Maker
Brewed coffee mess
You may be grinding the coffee to fine making the draining a little slower. There's something called a fast flow filter that may help also. Also, make sure that you aren't jamming the filter down to partially block the drain hole ensuring that it is freely draining out unobstructed
Aug 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Yard machine rider won't stay running
sound like you have some water in the engine, try removing the spark plug and squirting a little water repellent like wd40 or duck oil, crank it over a couple of turns, make sure the plug lead is away from the plug hole, then squirt some damp start in and refit the plug and try again.
May 02, 2009 | Garden
New Mr. Coffee Espresso machine producing white gunk
Hello aura20,
I bought one this week and had the same problem. I used vinegar and rinsed thoroughly and yet the whit flakes remained. I did some research and found that high end espresso makers often have very fine screens that catch minerals and grounds and so on. This Mister Coffee espresso maker has only a metal basket with tiny holes so it's not really filtering anything. Moreover the metal is treated aluminum, so it scales naturally. Also, if your water is hard like mine that just makes things worse. I just tore off a piece of paper towel only big enough to line the bottom of the filter basket and not come up around the edges. Then I put a drop of water on the paper towel and pressed the paper towel against the filter basket so I could see the little holes through the paper towel. Then I rinsed the machine again and the white flakes were completely gone from the water and the paper towel had collected it instead. I did the same thing with a new piece of paper towel and I added coffee, I did not add the maximum amount of coffee and I did not tamp the coffee. The product was smooth and creamy as it came out of the machine very slowly. But it tasted great and it was strong and clean. Upon removing the basket I found hard dry grounds stuck to the basket and paper towel. I had to use a spoon and running water to dig all of it out. It's not as good as professional espresso makers, but it'll do for a quick shot. I hope that helps.
Mar 04, 2009 | Mr. Coffee ECM20 Espresso Machine
Water overflows from filter basket
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Dec 25, 2008 | Mr. Coffee ISTX95
No flow
Tamp the coffee a little less - run water through filter basket to make sure it is dripping out before filling with espresso grounds. Dry the filter thoroughly before inserting coffee grounds. I would reccomend using double filter basket only instead of the single.
Aug 11, 2008 | Cuisinart EM-200 Espresso Machine
DeLonghi EC820.B Black Pump Espresso Coffee Machine Logo
141 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
