Question about Mtd Snowthrower Snowblower 5 24" Parts Manual Tmo-35275b 315-555-088
After it sits for a while the wheels will not turn and are stuck?
  • Mtd Master
  • 3,519 Answers
Hi William:
Snowblowers tend to get a lot of wet slushy use and if the are put away wet they can easily rust. Try to make sure all the mucky stuff is cleaned off (air hose works great) and spraying penetrating oil or WD-40 generously over all the moving bits except belts never hurts.
Posted on Apr 20, 2015
What is wrong with my car
That sounds very much like you broke off a tie rod end. Check to see if the front wheels agree with each other. Turn the steering far left, verify both front wheels are turned left. Turn the steering far right, verify both wheels are turned right. If the front wheels don't agree, DO NOT attempt to drive the car - have it towed somewhere or have someone repair the steering where it sits.
Aug 04, 2014 | 1999 Buick Park Avenue
Why does my T500 sometimes stop
if the machine has been sitting for awhile and you oiled it that will
help, it could be the belt is too loose or the motor is going out or the
foot pedal needs to be checked to see if something is wrong with it.
it would be a good idea to have the machine checked at a sewing
machine shop.
Oct 18, 2012 | Tacsew T500
Automatic Transmission Gear shifter stuck in park
Your front wheels might be turned to the right or left "binding" the suspension and actually holding the transmission in park. Try pulling the steering wheel with one hand so it is loose a bit as if you are turning the car while sitting still and then shift out of park. Some cars have a 'shift lock override' button also. This allows you to shift out of park without a key.
Aug 30, 2012 | Toyota Corolla Cars & Trucks
My steering wheel is locked and my ignition is also locked and wont allow me to turn the key in it.... what do I do? is it the lock tumbler and if so how do i get my steering wheel unlocked to be able to...
Hello and welcome to FixYa!
The gearing may have been stuck. As a first course of action, I strongly suggest that you spray WD40 on the ignition hole. Let it sit for atleast 10mins. then try to turn the wheel again while you switch on the key.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 30, 2011 | Dodge Neon Cars & Trucks
I can't get the front tires off of my 2007 dodge nitro
first the lug nuts must be removed , if wheel still stuck, try sitting and kick with foot flat or use mallet behind wheel with wheels turned to your advantage
Jun 27, 2010 | 2007 Dodge Nitro R/T New Cars
The ignition is stuck. How do i replace it?
if you can try spraying pb blaster in the ignition hole and let sit for a couple hours and try turning the key. also try moving the steering wheel back and forth at the same time as moving the key
Dec 01, 2009 | 1990 Honda Accord
Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Oct 04, 2009 | Pentair White/Gray Legend Platinum...
Turntable won't turn properly
Either the drive belt is stretched, or if it is a driven by an idler wheel, it may be damaged and need to be replaced.
You failed to mention the model. Which would help in determining the issue.
Dec 17, 2008 | Audio Players & Recorders
Mtd Snowthrower Snowblower 5 24" Parts Manual Tmo-35275b 315-555-088 Logo
101 people viewed this question
Top Mtd Tools & Hardware - Others Experts
Ted Maxwell
ray gallant
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Mtd Tool and Hardware - Other Expert? Answer questions, earn points and help others
