Question about Ricoh Office Equipment & Supplies
How can reset service call on Ricoh aficio mp201spf sc302
  • 126 Answers
SOURCE: sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Posted on Jan 08, 2009
Ickoajnc
  • 183 Answers
SOURCE: service mode
Press the “Up/Down arrow” keys together for about 5 seconds, and then press the
“OK” key.
“SYSTEMver x.xx/ 1. Service” appears on the display.
The machine automatically goes off line when you enter the service mode.
enter SP 5810 and reset the SC 543 **** if again appears please do not reset it again because you may do bigger problem and damage more part than ware damaged in first place .
The SC code says that the termistor is damaged so check on the fusing unit dose the termistor is standing in good position or has dirt on the surface of he termistor.
RATE ME IF THIS HELP YOU
Posted on Jul 17, 2009
  • 32 Answers
SOURCE: ricoh aficio 1018 i need to reset 541 code. when i
when u reset phot/txt mode button must also be pressed with ok button. press both buttons together
Posted on Apr 23, 2010
copyalbania
  • 96 Answers
SOURCE: All service codes for ricoh aficio 1075 are
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Posted on Aug 13, 2010
  • 903 Answers
SOURCE: service SC 990 RICOH
sc990 is a general software error. It could be caused by a specific application or function, or it could be caused by a problem with the process control. In general, you can get rid of the sc990 error by turning the machine off with the main power switch (the orange switch on the left side of the copier) but if the error comes right back, the best first solution is to update the machine's firmware.
Posted on Nov 25, 2010
How to reset SC 302 code ?
sc302 is usually PCU or charge roller.
As you say you have recently replaced the Drum/PCU, is the drum turning correctly?
Check charge connectors and connectors on the back of the pcu. To reset that code, simply turn main power off and on again. If problem comes right back....the machine detects the cause still exists. May be an issue with the HVT.
Sep 01, 2014 | Ricoh RICMP201SPF AFICIO MP201SPF,...
Functional problem sc302 in ricoh afficio 1315
this is a charge issue - a simple fix would be to remove the pcu and clean round its outside and then clean the contacts to it inside the machine - if this doesnt work the pcu needs stripping down
Oct 22, 2013 | Ricoh Aficio MP 1600 Black and White...
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Error Code on photocopier
Please clean or change the charge roller .The your problem in the HV parts.Verify the drum ground plate.
Nov 16, 2009 | Ricoh Office Equipment & Supplies
What error code 302 ricoh aficion 2016
Hi Manas,
Error code - SC302 is caused due to the leakage in charge roller.
In order to rectify the issue you need to replace the drum and the charge roller .
Nitin
Sep 11, 2007 | Ricoh Aficio 2016 All-In-One Laser Printer
300 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
