Question about Toro Garden
I have a Toro zero turn. The right control is not working? The left works as it should. Any help will be appreciated.
  • 579 Answers
Check the cable down to it's end, it is most likely broken. You may need to replace the cable. GOOD LUCK FRIEND.
Posted on Apr 22, 2015
5 Suggested Answers
headstrong56
  • 493 Answers
SOURCE: i have a zero turn toro z master and it will not turn to the left what is usually wrong?
hydraulics that control the left side
Posted on Jul 15, 2012
SOURCE: My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Posted on Aug 06, 2012
Testimonial: "Thank You very much for your support on this matter. "
mirab327
SOURCE: My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Posted on Aug 08, 2012
  • 6468 Answers
SOURCE: zero turn toro will only go in a circle
each side has a pump release lever on the rear did one side get pulled out to the push position?or not go all the way back after releasing it
Posted on Oct 11, 2012
Have z4235 right control just stoped working left works fine any suggestion
There are adjustments for this problem on each side of machine. Just follow the arms and you will see. This happens due to vibration. GOOD LUCK FRIEND.
Apr 20, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
Dec 26, 2014 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Toro z420
you have to adjust your tracking. Your manual tells you how to do this
Jul 23, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
My toro z480 zero turn wont move on the right side when I move the control lever??
Does it hum or make a binding noise when you push the lever? There are by-pass valves on the pump. If there is no noise then that's more than likely your problem. If you hear a soft grinding like sound at the wheel motor then it sounds like the motor is by-passing oil.
Aug 31, 2013 | Toro 60'' Zero Turn Lawn Mower Enclosed...
Left side drive began to shake and rattle then gradually lost all function. Right side working fine.
each side has is own pump and drive motor check the fluid level and then you will need to remove it and either replace it or rebuild it
Jul 30, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Steering problem
ther should be a turn buckle to adjust them to the same speed
May 21, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
The steering levers quit working on my zero turn Toro Timecutter 16-44.
My steering levers on my zero turn toro quite working, The mower wont go forward or in reverse any ideas on how to fix this.
Jun 12, 2010 | Garden
Garden Logo
80 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
