Question about Furniture
How do I remove the back from a rise and recline chair?
I need to remove the back of the chair to get it in my new house.
bomark2002
  • 160 Answers
SOURCE: the passenger side chair no longer reclines how
I believe you can, there should only be four bolts holding down the chair, when you git it off look underneath it and you will see the problem. If you have any electrical connections, don't worry the only plug in one way, and there are usually only one. Good luck man. (or woman)
Posted on Nov 06, 2009
  • 19 Answers
SOURCE: Invacare power chair model #1089384;
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Posted on Apr 07, 2011
diodeic
  • 1622 Answers
SOURCE: MY CHAIR IS IN THE RECLINING POSITION AND IT
The best thing to do in this situation is to call the vendor and have them repair it under warranty. There should be no charge for this service since the chair is brand new.
There are some checks you can make to avoid a service call. You have checked the batteries and hopefully the chair is plugged into the wall outlet. It is possible that something got disconnected under the chair. To check this you need to flip the chair over on its side or on its back since the leg rest scissor mechanism is extended. Look for any plugs that have come apart at their connections. Check for a pinched or binding scissor mechanism or tilt frame parts.
You should not attempt this at all if you cannot safely move a large piece of furniture. Perhaps a friend or relative may be able to help.
Insist that the vendor honor their warranty commitment ASAP. If you paid with a credit card, you should contact your credit card company to put the amount in dispute if the vendor is unresponsive. Hope this helps.
And you can troubleshoot with the below instructions if it with also help
things you'll need:
* Pride chair Owner's Manual
* Screwdriver
* Wrench
* Pliers
Instructions
Look at the chair's electrical plug, as the chair most likely became unplugged or the plug is not fully connected to the outlet. If this is the case, securely reconnect the plug.
Check the chair's connections. The electrical connections under the chair could be loose or connection cables could be pinched or bent. Tighten loose electrical connections with a small screwdriver and straighten bent or pinched cables.
Check the chair's transformer, motor and relay box under the chair as a malfunction in any of these could cause the chair to stop working completely. The hand control used by the operator to change the chair's position may also be malfunctioning.
Test the chair's wood frame, bolts and lift frame. Loose wood frames or bolts, overly tight bolts or the lift frame rubbing against the wood frame will all cause the chair to squeal.
Lay the chair on its side and check the wood frame and t-bracket. If the wood frame is rubbing against the lift frame or the t-bracket is cracking, you could hear popping noise. The t-bracket is the metal frame on the underside of the lift chair.
Check the dual motor timing if the chair will not recline all the way. The motors' timing could be off which would stop the chair from completely reclining. Put the chair on its side and remove the motor and plug it in. Use the hand control to turn the motor on and let it run until it stops on its own. Screw the push tube, located to the right of the drive tube where you just removed the motor, until you feel it bottoming out. Turn the push tube back two turns and grab the push tube. Turn the unit on with the hand control and allow the push tube to move away from the metal casing. Push the pin at the back of the push tube and reinstall the motor. This should re-time the motor.
Look at the wood frame, seat foam, leveling legs, motors and bolts if the chair is crooked. The wood frame could be twisted, the seat foam may be broken or misshapen, the leveling leg may need adjustment, the motor could be timed incorrectly or the bolts could be loose. If all looks in order, make sure the ground under the chair is level.
Unplug the chair before you begin fixing the chair.
Restore power to an inoperable lift chair. Ensure the circuit breaker box is connected to the electrical outlet. Make sure the external transformer is plugged directly into an electrical outlet.
Fix a Pride lift chair that only operates in one direction. Use a cotton swab to remove dust and debris from the toggle switch on the hand control. Flip the toggle switch back and forth to loosen any remaining debris which may be causing an obstruction.
Fix inoperable heat and massage features. Check the LED lights on the hand controls; the LED display is not lit, hand-tighten the connection between the hand control and the lift chair. Make sure the the heat and massage units are properly connected to the back of the lift chair.
Posted on May 02, 2011
SOURCE: This question is about a lazy-boy recliner not about a car seat. The chair seat should rise to let the person stand. It doesn't.
I don't know what that code means, but on my mom's Lazy Boy, it stopped working and I had to replace the two 9volt backup batteries on the power cube/wall plug.
Posted on Apr 25, 2012
  • 279 Answers
SOURCE: My wheelchair's green light doesn't come on after I return from my reclining position
Contact Pride for a manual, you'll need one. Or a Wheelchair/ medical equipment outfit.
Posted on Aug 02, 2014
Our chairs will not swivel properly. What can we do?
Purchasing a new high-quality Swivel recliner can be a better option for the problem.
You can get whole guideline and information about various different high quality swivel and non swivel recliners from Loveseat Recliner.
The best collection of trending swivel recliners are:
a. PULASKI BIRCH HILL
b. PULASKI HARMONY SWIVEL GLIDER
c. RECLINER GENIUS 360 DEGREE SWIVEL MASSAGE RECLINER
d. MONARCH SPECIALTIES IVORY BONDED LEATHER RECLINER
Jan 24, 2016 | Ekornes Stressless Recliner Chair Personal...
My air med us8000 massage chair will not fit through the doorway. Can the unit be made to remain reclined after shut off or can the arms be removed?
Most large recliners have removable backs. You must lift the rear shirt and look for the release latches. There will probably be an electrical connector or two as well if the device is a massage chair. Once you remove the back, then you can turn the chair on its side and then it should fit through most doorways.
Jan 02, 2016 | Furniture
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
https://www.youtube.com/watch?v=0P4cHbjiJmc
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
Sofa chair purchased 24/11/14 chair returned refund promised but not received
If you used Paypal to purchase the chair then you can initiate a dispute through Paypal. Paypal will require you to make a reasonable effort to resolve the issue with the seller first but then they will follow up for you.
Feb 26, 2015 | Klaussner Furniture 3 Pcs:...
What exactly is a recliner? How is it different from other chairs?
A recliner is a versatile flexible chair that more comfortable than any other chairs.
They are made up of fabric or leather and can be used for both sleeping and sitting.
You can get these recliners from Oversized Recliner, the best pieces available here are:
a. RECLINER GENIUS 360 DEGREE SWIVEL MASSAGE RECLINER
b. PULASKI BIRCH HILL
c. MONARCH SPECIALTIES IVORY BONDED LEATHER RECLINER
d. PULASKI HARMONY SWIVEL GLIDER
e. DIVANO ROMA BONDED LEATHER ROCKER
Aug 09, 2012 | Furniture
We live in a small apartment but would love to have a recliner to sit back and relax on when we come home from work. Is there such a thing as a smaller sized recliner that will not be as bulky and can fit...
Yes, you can a wide variety of small sized designer recliner in one of the best reputed place which is Loveseat Recliner.
Some of the attractive recliner available here are:
a. CLASSIC AND TRADITIONAL BROWN BONDED LEATHER RECLINER
b. COASTER HOME FURNISHINGS MOTION
c. RED LEATHER RECLINER CLUB CHAIR
d. SWIVEL GLIDER RECLINER CHAIR
e. ZERO WALL RECLINER CHAIR, and much more.
innovative-textile-solutions-plush-wing-recliner-protector-recliner-covers-5bjzt1amsw5yuu0bttpforya-3-0.jpg
What are the different types of leather office chairs?
Here are some of the most recommended recliners that would allow you to have a comfortable seat in office.
These reclining chairs are made up of best quality materials and are available at the cheapest price on Rise and recline chairs.
Some of the best available recliners available here are:
a. MARYLEBONE RECLINER CHAIRS
b. GROSVENOR RECLINER CHAIR
c. BLOOMSBURY RECLINER CHAIR
d. SAVOY RECLINER CHAIR
e. CLARIDGE RECLINER CHAIR
f. GRAFTON RECLINER CHAIR, etc.
Jul 30, 2012 | Furniture
How to remove swivel base from lazy boy recliner
This individual wants to remove the base from a recliner, not a tv. Take the back off the chair. Turn it upside down and remove four bolts, two front, two back that bolt the base to the chair on arms. Contact lazy boy first. You can get a new base from them that is stationary and put it in place of the swivel. I have same problem. Swivel is constantly turning and drives me crazy.
Jul 04, 2012 | Televison & Video
I want my living room to be comfortable and attractive. Which kind of chairs should I put there?
If you want a comfortable and attractive chair to put in your living room, the best option will be a reclining chair.
These chairs would provide you luxurious comfort and also luxury look to your living room.
Here are some best Rise and Recline Chairs:
a. BLOOMSBURY RECLINER CHAIR
b. SAVOY RECLINER CHAIR
c. CLARIDGE RECLINER CHAIR
d. GRAFTON RECLINER CHAIR
e. MARYLEBONE RECLINER CHAIRS
f. GROSVENOR RECLINER CHAIR
May 29, 2012 | Furniture
What is a recliner?
A recliner is a chair,generally made for one person, that when a lever is pulled, the back lowers andthe front rises. It allows the occupantto lie almost flat.
Furniture Logo
419 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
