Question about Whirlpool Washing Machines
Problem show f 6
Whirlpool washing machine shows prblem f 6
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
  • 662 Answers
SOURCE: key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error code F13 is showing
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
rickead1
  • 1998 Answers
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Posted on Jan 16, 2011
    HansPP
    • 2510 Answers
    SOURCE: Whirlpool washing machine showing a code of F08
    That is an overflow condition.
    Check the drain hose and make sure it is not plugged or kinked
    Check the wire harness to the drain pump, pressure switch and Central Control Unit
    Check and clean the drain pump filter of foreign objects
    Check for drain pump failure
    Check that the inlet valve shuts off fully
    Check that the pressure switch is operational.
    Posted on Apr 06, 2011
    My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
    Hello Janine Gooch,
    Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
    Finally ended up in AU ... No luck.
    (September 9th is only 6 hours old here (SF Bay area)).
    Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
    Whirlpool WFS1071BD Question and Answers
    Hope this helps (says top load... shows front)
    Carnac the Magnificent
    Sep 09, 2017 | Whirlpool Washing Machines
    Electronic board for AGI SS 50 whirlpool washing machine
    find the part number for the board and go on ebay to look for a new or used one boards our usually expensive so i would look there first
    Nov 20, 2014 | Whirlpool Washing Machines
    Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
    The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
    Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
    give it a try
    Kolbrun
    Feb 22, 2012 | Whirlpool Washing Machines
    Symbol showing on display
    you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual
    Dec 18, 2011 | Whirlpool Washing Machines
    I am planning to buy washing machine with capacity 6-7kgs. I want to use washing machine to wash blankets also. could you please suggest one of the following Samsung WA85VPLEC Whirlpool 650H LG...
    You should go for LG LG WFT7239PR as it provides an external Hot water inlet that will be good for greasy cloth wash. Also it has I sence tht may help better rinsing. LG has a good service rapot and their washing machines are more present which shows consumer confidence.
    Nov 20, 2010 | Washing Machines
    Whirlpool Calypso Mod: GVW9959KQ2, stops and shows "ob" as code for fast final spin. Also making high pitched whine during wash cycle. Appl svce place has suggested bearing or xmission. Any possible...
    Sorry to say but they are right. The Calypso washer was a horible design given to whirlpool from maytag. I would suggest you go buy new machine. Buy someting that looks simple and easy to use. The more complicated the unit the more problems you will have down the road.
    Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Washing Machines Logo
    24 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
