s
shalom Posted on Apr 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Konica Minolta bizhub 211 says: "machine in trouble call service C0501" what can I do?
IT ALSO SWITCHES ITSELF OFF
Jay Plesset
Level 3:
  • Konica Minolta Master 2,942 Answers
  • Posted on Apr 21, 2015
Jay Plesset
Level 3:
Answers
2942
Questions
Helped
668518
Points
9879
Konica Minolta bh 211 Machine trouble call(COF32)
https://www.manualslib.com/manual/837626/Konica-Minolta-Bizhub-162.html?page=174
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
How to clear memory in bizhub 211
what wrong with the machine before resetting it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Maintainance call display of konica minolta copier bizhub 211
Maintenance call? from your question it is not clear what is the error code.Please see if there is any code appearing besides maintenance call.Note the error code and tell me again so that i can help you.If it is C0500 or C0501 then press the stop button on the panel and restart the machine do not release the button until the code removes.
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
5helpful
C0501
turn off the machine, press the stop button, turn the machine ON, and keep the "STOP" button pressed, C0501 error code will reset in few moments...............
7helpful
3answers
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
13helpful
My bizhub has an error code of C0501
C0501 it is a trouble related with the Fusing Unit. Try to power it up with the STOP button pressed. If not, you may need to change your fusing unit.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
