Question about i-BLASON ArmorBox Series iTouch 5G iPod Touch 5G 5 5th Generation Hybrid 3
How do you ulock an ipod touch when it says ipod disabled connect to itunes
My ipod touch is disabled how can i ulock it
What most likely has happened is that you or someone was trying to access your iPod and tried to enter a passcode to get in. After a certain amount of tries, your iPod will disable itself. Here's how you can get it back.
Step 1: Turn on your computer, and connect your iPod to your computer with the USB cable that came with your iPod.
Step 2: Open up iTunes on your computer.
Step 3: In iTunes, go to the left side of your screen and scroll down, when you see your iPod, select it.
Step 4: You should now see on the right side of your screen some general iPod information. Scroll down to until you see a "Restore" button.
Step 5: Hit Restore, and wait for a few minutes. THIS WILL WIPE EVERYTHING THAT WAS IN YOUR IPOD AND RESYNC IT WITH EVERYTHING THAT IS IN YOUR ITUNES LIBRARY.
This is the only working method known.
Jan 26, 2011 | Apple iPod touch
I have an 8 gb ipod touch that is now disabled because I can't remember the 4 digit code. The message on the ipod's screen says 'ipod is disabled. Connect to itunes.' The computer that I originally used...
connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
this process is all on the computer.
May 20, 2010 | Apple iPod touch
My 8G IPOD TOUCH IS DISABLED IT GIVES ME A
download itunes from
http://apple.com/itunes
install it connect your ipod with your pc
Nov 23, 2009 | Apple iPod touch
My ipod touch is disable.it tells to connect to itunes
plug in your ipod to your computer open up itunes and when your ipod appears under the devices section click on it and then under summary you can restore and reset the ipod
Oct 15, 2009 | Apple iPod touch
Ipod is disabled connect to itunes
Go on to itunes and plug your mp3 in to your computer
and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
Aug 19, 2009 | Apple iPod touch Second Gen (8 GB,...
Forgot my ipod touch password and now its disabled
Connect to iTunes, go to the settings menu of your iPod (click on the picture of your ipod on the bar on the side.) Then click "restore my ipod's settings," or something similar to that. You will have to re-sync your ipod, but your password will be removed. hope it helps
Jul 21, 2009 | Apple iPod touch
8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
if you need any further help let me know.
Good Luck
Jun 01, 2009 | Apple iPod touch
Hey,
read this page i posted
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
Let me know if you need anything else.
Thanks,
Ekse
Jan 20, 2009 | Apple iPod touch
Ipod is disabled
Hold sleep and home button for ten secs (or until you see recovery mode screen) then connect to itunes
May 18, 2008 | Apple iPod touch
i-BLASON ArmorBox Series iTouch 5G iPod Touch 5G 5 5th Generation Hybrid 3 Logo
146 people viewed this question
Top i-BLASON Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an i-BLASON Audio Player and Recorder Expert? Answer questions, earn points and help others
