Question about Tecnik Dishwashers
I have a tecnik dishwasher SE6TIE1GB/29 and the lower basket has rusted away. I am told the basket is no longer available, any suggested replacement for this model?
skrbin
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
buffalonyman
  • 1865 Answers
SOURCE: how to repair rust on lower basket of dishwasher
Use sandpaper or brillo pad to remove rust, and paint it with acrylic appliance paint
Posted on Apr 15, 2009
woodchuck789
  • 4066 Answers
SOURCE: need to find out where I can buy a lower basket
Here's one of several on line sites. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=235621&diagram_id=7217#d7217
Posted on Mar 03, 2010
  • 257 Answers
SOURCE: My dishwasher lower basket has some rust. Is there
the paint dose not work well, If the wire is not in a super critical place, I sometimes cut them out and cap them with a rubber coated dishwasher repair kit that I purchase at my local appliance repair shop. You can probably order that on line, I found them here.. http://www.searspartsdirect.com/partsdirect/part-number/675679/0022/665?sid=SPDx20101116xGPROD
Posted on May 10, 2011
heatman101
  • 43501 Answers
SOURCE: Kitchenaid dishwasher model kudm24se the
That is not that hard to replace and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on Jun 02, 2011
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
Dimensions of fully integrated dishwasher
few things - the techik dishwashers are rebaged Siemens dishwasher. You have the correct model number but for a minor mistake - the "l" is actually a "1". Should be se6tie1gb/13
See if you can load this installation instruction. The dimensions are there.
https://portalcn.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
if no luck then it is
Apr 23, 2014 | Tecnik Dishwashers
I was told that my Tecnik SE6TIE1GB/17 Dishwasher is a bosch. I have seen the news today that some models have been recalled can you tell me the full E-NR number please
The recall is only for freestanding or semi intergrated d/w. If your control panel is along the top of the door it is not subject to the recall.
Mar 15, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Kitchenaid dishwasher model kudm24se the upper and lower baskets have rusty areas. Would like to replace with new baskets or a method of correcting or fixing the rust spots
heatman101
Jun 02, 2011 | Dishwashers
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Apply rectorseal where lower p-trap comes together.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The electrical consumer unit trips when the dishwasher is on, swicthing all the sockets off in the house. An electrician has told me it could be a number of things, namely a problem with the neutral, some...
You might need to contact a different electrician. Also a different retailer of machines as this one is obviously trying to make a sale. The apparent problem is that the house is wired with all of the outlets in the house on one circuit breaker--a recipe for trouble. Any house with multiple outlets should be divided into zones so that the whole house doesn't shut down if one appliance trips the breaker. A heavy user of power like a dishwasher should have it's own breaker and wiring for that machine alone. The electrician should have load-checked the dishwasher to make sure it is not drawing more than rated power, then suggested that it be wired to it's own breaker and circuit. Any other high power appliances should also have separate circuits (washing machine, microwave, toaster, etc.). Hope this helps!
Mar 25, 2010 | Tecnik TKL9260 Front Load Washer
How to repair rust on lower basket of dishwasher
Apr 15, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Tecnik Built In Dishwasher SE6TIE1GB/17
You can try reseting the machine buy holging down outside two cycle buttons for 3 seconds, then release. After a minute the end light should come on. Then use as normal. If this fails pull the unit out, then take of the side panels (screws to the front in the seal) & check the red anti-flood float on the left side of the machine, to make sure it is not up activating the cut out switch. This may be due to the machine leaking somewhere and the float raises and activates the switch, or as in my case a build up of limscale has raised it up enough to activate it.
Hope this helps
Mar 06, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Soap Dispenser
Buy tablets and sit them on the cutlery basket, when I bought mine the shot told me to do this to get better cleaning.
Aug 22, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwashers Logo
55 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
