Question about Samsung RF4267HARS Stainless Steel French Door Refrigerator
None of the evaporator fans are working. Could this be a problem with the main board or the fans themselves?
  • Samsung Master
  • 5,323 Answers
There is usually only 1 evaporator fan? or do u mean the condensor fan as well? u can check both with a meter for ohms r u saying the fridge still works but no fan operation?
Posted on Apr 22, 2015
  • Jason Valdes
    Jason Valdes May 04, 2015
    You are correct, non of the fans are working. The evaporator fan and the two condenser fans. I checked the ohms and the fans are still good. It seems they don't get any power? Is this a problem with the board?
  • Jorge Rendon
    Jorge Rendon May 04, 2015
    could be did u check the fan wire lines and follow them thru making sure they are not damaged
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Frigidaire fridge model FGUN2642LF6 fridge is not working. Code displays sy and ef, what is wrong
Your evaporator fan is not spinning.
Check to make sure there isn't any ice build up jamming up the fan. If there isn't then it's either the evaporator fan, or the main board.
Aug 14, 2015 | Frigidaire Refrigerators
Why doesn't my evaporator fan in my refrigerator come on?
Some evaporator fans are controlled by a door switch that prevents fan from running while door is open. Switch is usually located in the area near door front and is either a push button or rocker type. If no switch there could be a control board that is defective. Those refrigerators that have a main mother board control system run all components through that mother board. Hard to tell exactly with out a brand and model number.
Jun 29, 2015 | Frost Refrigerators
I have replaced the evaporator fan and the main board and am still getting the ef error code
Hi, your unit has a loose harness behind the fan motor at the wall. Manually push in every wire to assure a good connection, the error you have is that the control can't sense the fan speed. Unplug the unit when you do this to assure the computer can see and sense the fan. Failure to unplug first will not work. Good Luck.... PS once fixed use a sealant to keep these connection tight and clean.
Aug 17, 2014 | Frigidaire Refrigerators
Evaporator fan not running
Hello Richard Black - From what you have described it sounds like the refrigerator is experiencing a wiring failure or has a faulty control board. I suggest contacting a professional to accurately pinpoint any potentially more serious issues.
Jan 24, 2013 | Frigidaire FPHS2699KF (260 cu ft) Side by...
Freezer flashing E Refrigerator flashing F what does this mean????
The code "E - F" is related to evaporator fan motor. You have a bad evap fan. This is the fan that is behind the back panel INSIDE the freezer.
This code is for the evaporator fan motor but it could also be due to a defective main board. If the fan motor in the freezer is still running, disconnect power to the refrigerator for 30 seconds and then reconnect it. This resets the board. If the code disappears and the motor is still running, it may be ok now but if the code reappears, the board will need to be replaced.If the motor is not running, some voltage checks will need to be made at the motor and at the board.------------The EF error code indicates a problem has been detected with the freezer fan motor (evaporator fan). This type of symptom could be caused by the fan motor stalled out on some type of obstruction, defective fan motor, faulty wiring or the main control board.
you can get required parts from sears part direct online site or from repairclinic.com site.---------
This should help.Thanks,.Helpmech.
Apr 04, 2011 | Kenmore Refrigerators
I just replace evaporator fan but still won't work. Is there a fuse for the motor? thanks
You will have to replace the main control board . This board is behind the refrig , behind an 8 " X 10 " panel . This board , is usuall the cause for the evaporator fan motor not to work . It is easily replaceable .
Jan 28, 2010 | GE Refrigerators
Mastercool swamp cooler fan doesnt come on.
Are the relays perment on the board or are they seperate from the main board? If they are mounted to the board, you will need to replace the board. Sounds like you are getting a call to the relay but none leaving so this would indicate that you have a bad relay switch.
Mar 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
Samsung RF4267HARS Stainless Steel French Door Refrigerator Logo
83 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
