SOURCE: 2006 honda element
It sounds very much like your battery is discharged, and does not have enough charge left to turn your engine over (the clicking noise is your solenoid trying to engage the starter, but it is not getting enough power to do so). The fact that your various little lights work does not indicate that you have nearly enough of a charge in the battery to start the car.
I think that if you have your battery charged (or replaced, if necessary), that will solve your problem. You might take the battery to Autozone or a place like it and have them check it for taking a charge (I don't think that charge for that).
Hope this helps you.
SOURCE: I have a 1998 BMW
Do you have an owner's handbook? What happens is that they use a rod that looks like a big screw. If that track has been damaged in any way, it can bind and may require excessive force to close. The manual indicates that some resistance is felt at the halfway point and that if if triggers it to retract, to hold the button forward. If this does not work, I would push with my hand while holding the button til it is closed. The headliner may have to be removed to gain axcess to be repaired. Let me know on the owner's handbook and what you find with the sunroof.
megan 03
