Question about General Wire Electrical Supplies
I had to unwire my ceiling fan and kitchen light to move a wall, and now I rewired them they come on , but when I shut them off they blow the circuit breaker. any help please
    Top Expert:
  • 10,875 Answers
Hire an electrician before you burn the house down
Posted on Apr 21, 2015
  • 2,223 Answers
Your wall switch must have to different phase hot wires going to it. when off, no problem, when on it is a short. be careful
Need help rewiring two single celing fan and kitchen lights wall switches.
Two single switches operating a ceiling fan and a ceiling light?
Aug 06, 2017 | Electrical Supplies
I have two ceiling lights in a room. Want to install ceiling fan in one outlet. How do I wire it so that I can have fan in one place but turn off light in other? Do I have to hot-wire ceiling fan?
You simply use the ceiling fan switch to power the fan. U can hook it up in parallel to the other light fixture. The wall switch can power both units but you can always shut off the fan. To run the fan and kill the light you would need a separate circuit for the light with its own switch. Or hot wire the fan as you indicated.
Jul 26, 2017 | Dryers
Fan will not work unless wall switch is on
A ceiling fan can be wired in different ways.I prefer to connect only the lights to the wall switch,and the fan to the hot,so the fan can be used when the lights are turned off.You will need to locate the circuit to the fan and turn off the breaker.Remove the cover at the ceiling to access the wiring.The fan wiring is usually labeled,but I believe the light wire is blue,the fan wire is black,and the neutral is white.The light wire and fan wire are probably both connected to the same feed.You will need to rewire the fan to the hot(black) house wire.The light wire is fed from the wire after the wall switch-leave this as is if the lights turned on/off with the wall switch.After the rewire,turn the breaker on before replacing the cover,and verify everything is how you want it before replacing the cover.I usually remove the light chain to keep people from using the chain instead of the wall switch.
Jul 07, 2012 | Dryers
Ceiling fan will not spin fast
in england the usual house current is 220 volts and here the current is 120volts. this explains the problem. unless there is a switch to change your fan to a 110 current built in it might make sense to buy a new fan and move on. rewiring it would be expensive and unless it has alot of sentimental value probably not worth it.
May 31, 2010 | Hampton Bay Dryers
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Hampton Bay Garrison 52" fan stuck on high
nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Jun 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Wiring in Ceiling fan remote. Lights flicker
dip switches are not on the same signal?
Sep 07, 2008 | Hunter 27185 Remote Control
CEILING FAN 3SPEED 4WIRE HUDSON BAY
Usually when you say 4 wire, the correct electrical definition is 12/3 or 14/3 with a ground, depending on the amperage capacity of the circuit that the fixture is powered by. The bare copper wire is case ground which goes to the metal body of the fan and is combined with all the other bare copper grounds in the switch box on the wall. The white wire is the neutral or return. it is connected to the white wire in the fan at the ceiling box and combined with all the other white wores in the switch box. The black wire is usually the light power which is then connected to the appropriate connection (labeled) on the switch in the switch box on the wall. The red wire is the power for the fan (which is also labeled) in the switchbox on the wall. Sometimes the wiring at the ceiling box is not 4 conductors especially in older buildings, then the fan and the light power wires are combined at the ceiling box with the existing black wire. Then the ceiling fan and light goes on and off at the wall switch together and the speeds are controlled by a pull chain at the fan. The kight can be shut off with a pull chain also so that the fan is on onl.y.
Jun 08, 2008 | Optics
Wall switch
I had this same problem (sort of) - my daughter lost the remote to our fan and it would not work from the wall switch. What you have to do is go up to where your fan is connected to the ceiling, slide the canopy down, and remove the remote transmitter. Then just rewire the fan normally - white to white, black and blue to black, and the ground wires together. Turn on the power and your fan light should work with the wall switch. You will have to pull the cord for the fan to work.
Jan 07, 2008 | Honeywell HFS641P Stand (Pedestal) Fan
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Oct 20, 2007 | Hampton Bay 24002 Ceiling Fan
Electrical Supplies Logo
203 people viewed this question
Top General Wire Electrical Supplies Experts
Steve Mason
rdjagger
Are you a General Wire Electrical Supply Expert? Answer questions, earn points and help others
