Washer will not start. Water flows through. Outlets are live. Ideas?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door inter lock also pressour switch
Posted on Apr 21, 2015
Cabrio washer is getting OL code after about 10 mins.
see http://forum.appliancepartspros.com/washer-repair/192305-cabrio-washer-code-ol.html as more ideas on this type of problem suggested
Mar 27, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
What is LF message
LF means a long fill was detected. This means that the washer sensor did not sense enough water coming into the unit in the first 8 minutes after starting the wash cycle.
There are several things that you can check. First, make sure that the incoming water pressure is good. You can try replacing the intake hoses and checking the filters on both sides (inside the washer and at the shut-off valves). (When you take the hoses off the shut-off valves, put a bucket under the outlets and check the flow rate.) Some intake hoses will seal themselves if they detect a leak. This will significantly reduce the water flow. If the filters are clogged, you get a similar restricted flow.
Next, check that the end of the drain hose is not positioned below the fill level of the washer. This will cause the water to be suctioned out of the tub as fast as it fills.
If the water is flowing well, the intake valves or the water pressure sensor (which detects the change in the weight of the tub) could be bad or have a wiring harness problem.
I hope this helps.
Aug 25, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Yesterday, I noticed that the Hayward pool sweep wasn't moving, nor was there any water flowing from the outlets in the pool. I cleaned both baskets - nothing. I installed 4 brand new cartridge filters -...
A pump motor running without any flow of water is one of two things. The impeller inside the pump that is connected to the motor is broken or clogged. Open up the pump and inspect the impeller for debris or seperation and clean or replace as needed.
John
Dec 23, 2010 | Hayward Pool & Spa
My new washer keeps giving the message, " no water, open water valves". Well, all the valves are open and correctly connected to cold and hot outlets going into the washer. What could be possibly wrong?
Possible that the water level sensor is not detectingg the level after the set time .It can also be due to slow fill or poor flow.
So check the water level sensor.
Sep 15, 2010 | Electrolux AWW1417 Front Load Washer /...
Will not take softner?
clean the dispenser drawer, then using thin pipe cleaner clean the two outlets that fall over the softner drawer, its easier if water is flowing from them, to do this switch on the servvice cycle (no clothes in the machine) as u swtich it on, hold the start pause and skip button down and then press the fabric button repeatedly until the water comes through the outlets over the softener compartment.
to exit service cycle u must swtich the machine on and off twice
Dec 28, 2009 | Zanussi FJS1225W Front Load Washer
No flow
Hello hedrickcari
Welcome,
You said, you are getting a no flow error code. This washer was installed today.If I have an air pocket, how do you get it out so the washer senses the water flow?
First I would unplug the washer for 5 minutes and see if it resets and clears the errors!
Make sure the door is tightly closed. (Unlike top-loaders, front-loading washing machines must be closed in order for water to begin filling. Makes a lot of sense when you think about it.)
Then make sure the machine is plugged in to a live (or working) electrical outlet. It's a good idea to check the appropriate circuit breaker and reset it if needed or check the fuse if you have a fuse box.
Next, turn the control dial to the proper cycle and push the START/STOP button firmly. Then turn both faucets (hot and cold) on all the way. Take a look at the inlet hoses (which go from your pipes to your washer) and straighten them out if necessary.
Turn off the faucets and then disconnect the hoses. Clean the hose filter screens to remove any blockage that could be plugging up the water line.
Then replace the filter screens, reconnect the hoses, turn the faucets back on, open and close the door, and push the START/STOP button firmly one more time.
You should be rewarded with the sound of water beginning to fill up your Maytag® Neptune® washer. If you aren't, please contact Customer Service at 1-800-688-9900.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
