Question about Vornado Dryers
Variavle speed control replacement
Model 280LS SN JFM90 has defective variable speed control
3 Suggested Answers
nanbuenbrazo
  • 553 Answers
SOURCE: I have an existing ceiling fan with a three speed
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Posted on Nov 01, 2009
rogrrabbit
  • 986 Answers
SOURCE: I have 3 ceiling fans with variable speed control,
The Humming indicates the motor itself is going out. Its going to need a replacement soon.
Posted on Jun 27, 2010
Testimonial: "The instruction said it's suitable for solid state speed control, and so I returned the motor and got a new one."
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
Lionel Train transformer goes full throttle only
Sounds like the "variable resistor" that allows for a variable speed is either defective, or has become corroded on it's switch contacts. You might get lucky with some electrical contact cleaner spray and spraying it in or around the variable speed switch. Otherwise, I'd just invest in a new transformer.
Dec 16, 2011 | Lionel Cw 80 Transformer
Toyota 2000 camry fan only working on high speed
The blower motor resistor pack is defective and must be replaced. The resistor pack controls the variable speeds.
May 01, 2010 | 2000 Toyota Camry
Heater only blows on hi speed all other speeds are not functioning
HI. This will be the cause of a defective resistor switch. The speed variables have been damaged. This will happen, overtime. The necessary action will be to have this damaged switch replaced. This will be the actual switch that is located, and housed within the control cluster in the dash.(Speed selection switch)
Feb 01, 2010 | 2004 Chevrolet Silverado
Spin half the speed
Hi.
Depending on the make and model, and type of washer, you may need to test and eventually replace the following parts:
On top loads:
Variable speed motor .
Motor coupler.
Transmission.
Control board.
Motor control unit (if present)
On front load :
Motor coupler.
Control board.
Motor control unit.
On top load the problem is often transmission or variable speed motor. On front load MCU or motor.
Dec 14, 2009 | Washing Machines
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
Poor spin quality
That means that either timer control board, motor control unit, or variable speed motor are defective, and for that reason the cycle is not proceeding at normal speed.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 05, 2009 | Washing Machines
Washer will not spin or agitate. it makes a clicking noise
That means that either timer control board, motor control unit, or variable speed motor are defective, and for that reason the cycle is not proceeding.
Volkswagen Beetle 2000 TDE
P1557- Charge Pressure Control: Positive Deviation Possible Symptoms You May have overboosted I would chek out the EGR make sure it is open.
  • Reduced power output
  • Limp mode
Possible Causes
  • Boost Pressure too High
  • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
  • Charger Pressure Control defective
    • VNT (variable nozzle turbo): nozzles stuck
  • Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
  • Check Hoses/Pipes to/between Components
  • Check Solenoid Valve for Boost Pressure Control (N75)
  • Check / Clean / Replace Charge Pressure Control
    • Check / Clean mechanism for variable nozzles
Aug 02, 2008 | 2000 Volkswagen Beetle
Dryers Logo
82 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Steve
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
