Question about Skytex SP729 - New Skypd 7in 4.2os Dual Tab
Sent in to be repaired. Dissatisfied that they could not find anything wrong although your tech William worked different days and could not get it to work. how do I get the Skypad returned?
See Above
My daughter-in-lase STEPPED ON my granddaughter's Nook!!!!! Now, although the screen is not broken, there's nothing but lines all over the display. Is there any hope of saving it?
The device cannot be fixed.
Your information is another matter. Any book, music or app you bought will still exist in the account. Also, ANYTHING sent to the cloud will still be there.
All else you put on your Nook is gone unless there is a copy on a PC where it was originally.
If anything was transferred to a SD card, it is still there.
Mar 10, 2017 | Barnes & Noble Nook Tablet
DL721-RB tablet screen is not working. 2 days old.
Send it back for warranty, any attempt to repair will void the warranty.
Jan 09, 2017 | Tablets & eReaders
I dropped it and although the screen isn't physically broken, it's not working properly.
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
iPhone Screen Not Responding - how to fix? - Tech-addict
www.the-tech-addict.com/iphone-touch-screen-not-working/
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Dropped phone, screen doesn't work. What repair kit do I need ...
forums.androidcentral.com > ... > Samsung Galaxy S3 > Sprint Galaxy S3
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
How do I get my pictures off my phone if I have a broke screen ...
Mar 10, 2014
Brand new Galaxy S4 "broken" for no reason.
Aug 12, 2013
Does the digitizer break when screen is cracked on the Nexus 7 ...
Aug 3, 2013
TF700T now won't turn on.
Oct 15, 2012
More results from forums.androidcentral.com
Feb 03, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
I sent it to tech r m a department. how long will it take to fix it or get replaced
Well, how long does it take to fix or replace ANYTHING? That's it!
ask the technician who is working on it.....
Jul 14, 2015 | Tablets & eReaders
I did not receive the book I ordered; the wrong edition/different book was sent. What do I do?
contact the supplier direct with all the details and sort it out with them
Jun 18, 2015 | Tablets & eReaders
My battery will not charge, is there any help for this?
When you can't find what is wrong, the battery, the connector in the tablet, the cabling (in the tablet or from the charger) or the charger, you should ask a tech person, if he / she can find what is wrong. Most phone repair shops can find what is wrong if you take everything there. Before you leave anything there for any repair, first ask what they will charge you EXACT.
Jan 15, 2015 | Nextbook Tablets & eReaders
Keyboard does not work
Hi patricia
Sorry to hear about your new tablet Unfortunately if it does not work now it most likely theres nothing going to fix it. I would return it before you do anything that might cause the warrenty to be invalid. Have you tried the tech support route ? If they deem it DOA then you can return it and try something different.
Good luck
Chadman
Nov 11, 2014 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
Trio stealth g2 shows my internal storage space as "0", it won't let me download apps, or updates. I have reset my tablet several times (pwr down volume)... erased everything I could. I know my wifi is...
My daughters tablet did the same thing. After we had it for about 2 weeks. Called Trio tech support. Ended up having to send it to them and they sent me a new one.
Mar 17, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Keeps freezing after loading windows xp, won't allow me to use any apps or open anything
if you cant afford to get it repaired, then check the processor, hdd, ram slots to ensure that they are all in their fixed possitions,
the problem may be that a module of ram has come loose or your processor has, if they haven't then get yourself a digital multimeter and learn about computer electronics,, although buying a new computer maybe the quickest option.....
May 31, 2009 | Compaq tc4400 Tablet PC
Skytex SP729 - New Skypd 7in 4.2os Dual Tab Logo
27 people viewed this question
Top Skytex Tablets & eReaders Experts
Are you a Skytex Tablet and eReader Expert? Answer questions, earn points and help others
