Question about Acer Computers & Internet
If the machine is lock it shuts down and the paddle does not turn
  • Frank  Fernandez
    Frank Fernandez May 16, 2015
    Hi johnnie gouws, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Why won't my paddle turn
My paddle won't turn in my Breadman TR 400. - Fixya
www.fixya.com/support/t20366573-paddle_turn_in_breadman_tr_400
Sep 27, 2013 - Posted on Sep 28, 2013.
Breadman TR850 Plus Bread Maker Paddle turn ... - Fixya
www.fixya.com > ... > Breadman > Breadman TR850 Plus Bread Maker
Paddle won't turn in the breadmaker with any resistance My breadmaker paddle won't turn under pressure. I put all the ingred. in and turn on the machine.
Amazon.com: Customer Reviews: Breadman BK1050S 2 ...
www.amazon.com/Breadman.../B003ZDNKSI
Amazon.com, Inc.Breadman BK1050S 2-Pound Professional Bread Maker with Collapsible ... So thepaddle turns and kneads while it goes in one direction. ... So, while I still love mymachine, I do a lot more bread by hand now. ..... Maybe I got a defective unit... but Iwon't be risking it... sending it back and exchanging for another brand.
Amazon.com: Breadman 34923 breadmaker paddle.: Bread ...
www.amazon.com/Breadman...paddle/.../B0041TMO...
Amazon.com, Inc.
Rating: 3.9 - ‎61 reviews
Turn on 1-Click ordering for this browser .... If I don't scrape down the sides a couple of times during the initial mixing, the loaf won't turn out correctly. ... This paddle fit my Breadman TR520 Programmable Bread Maker for 1-, 1-1/2-, and ...
Jan 01, 2016 | Breadman Bk2000b 2-1/2-pound Bakery Pro...
Kitchenaid artisan mixer locking switch only locks 3/4 the way and motor head bounces when mixing dough, although is still locked down.
Make sure that the hinge pin is locked up firmly with the grub screw that is accessed with machine upside down on a towel. It is right up the middle of the pedestal. Next fit bowl & flat paddle and adjust head height with the screw that you can see when the head is raised up. The screw is right in by the middle of the hinge for the head unit. Screw it in (clockwise) a bit to lower and anti clockwise to raise. You want to screw it in enough to just hear the paddle tinging on the bowl and then anti clockwise the screw so it just clears. 1/4 turn from tinging is roughly it. If the head is still not locking down you may need to run a rat tail file through the locking slot to allow the lock better engagement. This is a last resort, if you file too much it is permanent and cannot be reversed so don't do it until everything else has been done properly. It's not a big job for your local Kitchen Aid service agent to sort out for you.
Dec 29, 2014 | KitchenAid Kitcheaid 5 Qt. Artisan Stand...
Dooor lock will not unlock turn machine on it does nothing but click
Either the Central Control Unit or door latch assembly I have seen door latch assemblies ohm correctly and still be bad cheaper to change this first to manually unlock can't remember if this has a removable bottom panel if so three screws remove panel to reach into unit and up where lock is located there is a little white paddle pull down to unlock if no panel remove top reach down same area find paddle pull down a little tougher.
Jan 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
The drum paddles have came loose from the machine
Have all drum paddles come loose? Generally there is one anchor bolt accesed through on of the paddle holes, usually the third from the front. Press down and away from you towards the back of the machine and tighten the bolt
The paddles have slots on there underside and coresponding hooks on the drum of the machine, hence the "push down and away" action to hook up the paddles.
Hope this helps
Duncan
Mar 04, 2011 | Whirlpool Washing Machines
My machine counts down time, but the paddles don't rotate, they are free to do so as I took out the pan. when I restart the setting I get a Hor notification on the time area.
That may mean that your machine is detecting that it is not at the right temp and some machines heat up for a few minutes before the paddles start to turn. Try pushing the start button for the Basic bread program and wait 5 or 10 minutes. The paddles should start to turn.....Let me know if this works thanks!
Oct 10, 2010 | Black & Decker B2300 Bread Machine
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Paddle won't turn
Although my Oster breadmaker is older (5811) it had the same problem (frozen paddle) and I just fixed it today. First read this article on maintenance: http://www.breadmachinedigest.com/tips/bread-machine-maintenance.php, then watch this video on disassembling a breadmaker: http://www.youtube.com/watch?v=ReTBIc3qTT0. The good news is the bottom comes more easily than the video and the workings are easier. If your belt is fine (which mine was since Oster is grooved differently than the video) then First turn the big wheel by hand a few times to "unlock" it's stiffness. Then remove the big wheel and belt. Oil both of the spindles with MACHINE OIL ONLY (like the first article emphasizes)--I used sewing machine oil. Mind you, I did this with my machine upside down to be sure oil ran down the shafts. Then re-assemble. This was a BBBBitch to do until I discovered the spindle on the big wheel is shaped like an elongated D. Once you figure that out, it will drop down easily. I stretched the tight belt back on by fitting it first into the smaller paddle end (to be sure the grooves are in place) then putting it around the big wheel, holding loose part with thumb and turning the wheel until it fell into place--sort of like a tire machine. (see attached picture) Now give it a few more spins by hand (it should spin freely) and replace bottom of machine. Voila. Mine is working perfectly now, and I hope yours will too.
Feb 10, 2009 | Oster 5834 ExpressBake Bread Maker
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
It is the little metal plate that locks the paddle shaft to the big sprocket. the little flat spot is worn away. now where do I get a new one, it is may be worth a penny.
Jul 04, 2008 | Kitchen Appliances - Others
Computers & Internet Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
