Question about Belling Ovens
Where is thermostat for oven on belling compact deluxe cooker
  • Belling Master
  • 5,323 Answers
Which thermostat please try to be more specific
Posted on May 11, 2015
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: cooker problem
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Posted on Dec 15, 2008
  • 417 Answers
SOURCE: belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Posted on Dec 22, 2009
Testimonial: "thanks ashburton i will attempt to change the element first."
  • 193 Answers
SOURCE: Belling Electric Cooker - Main oven keeps tripping electrics
yes use an ohm meter to test it
Posted on Apr 29, 2010
sodeep
  • 3267 Answers
SOURCE: belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
Posted on May 08, 2012
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Tip
Belling Elements
on Aug 25, 2010 | Belling XOU592 / XOU593 Electric Double...
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Belling oven stopped working
Dec 22, 2009 | Ovens
How do i take out the old cooker element on my belling xou252 cooker
If it is a fan assisted oven, then the element should be behind a removeable cover at the rear of the oven,
Be careful not to lose the wires behind the oven compartment.
Hope this helps.
Dec 19, 2009 | Belling XOU252 Electric Single Oven
Cooker problem
Dec 15, 2008 | Belling Ovens
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
