Question about Leeds Garrity 3AAA LED Flashlight - K9 36: $17.31
I have this flashlight,but the on/off button does not work.Is it possible for a replacement?
I would appreciate any help you can give me,Thankyou quiltman60@yahoo.com
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
Marantz PM-66 SE: Power light comes on, but the amp does not work
try taking a flashlight and look through cover into unit for a blown fuse or take cover off (which is better) if taking cover off unplug unit. If a fuse is blown remove it and take to a store like Radio Shack for proper fuse watt and amp..if fuses are ok i would get it fixed...sounds like a minor problem since main power is there. GL
Aug 08, 2014 | Marantz Audio Players & Recorders
I have samsung lcd tv LA32B. A couple months ago, the tv worked well. Then something went wrong. I had to wait 5 minutes to see channels appeared in the screen. A month ago, my tv could not display all...
try the flashlight screen test with TV on to be sure an image is showing, hold flashlight above at an angle, if you see a faint image the motherboard needs replacing
Oct 30, 2017 | Samsung Televison & Video
TV will come on for about 3 seconds and picture goes out on it but you can still hear it. please help me i love my tv.
Turn set on and press a bright flashlight against the screen. Look around the edge of the flashlight for moving images. The image should still be there. The back light is off so you can not see it.
The problem is most likely in the back light inverter board. Possibly one transformer on the board is causing the unit to switch off after the fault is detected.
You should replace the back light inverter board.
Since you did not give the model of the set I can not give more information.
Mar 04, 2011 | Sanyo 42 in. LCD TV
I accidentally drop my gerber firecracker flashlight, when I turn it on its not working any more.How can I detach the crown from bulb to fix the problem.Thanks for the help.
Hi I had the same problem. It seems that when I dropped it the back buttton got stucked, so what I did was to unscrew the back part (as if to replace the battery) and gave it kind of gave it a knock or hit it softly just to jiggle the button. Scre it back on and got it to work, Hope it works for you.
Jan 18, 2011 | Gerber Blades Gerber Firecracker LED...
My Lg ku990 does not bring out that camera flashlight when i take pictures. I tried resetting the phone,changing the "ISO" from Auto to function to 800,but still no flashlight. Please help. Your assistance...
My Lg ku990 does not bring out that camera flashlight when i take pictures. I tried resetting the phone,changing the "ISO" from Auto to function to 800,but still no flashlight. Please help. Your assistance will be highly appreciated.
Aug 05, 2010 | LG KU990 Viewty
Broke my gerber 3.0 flashlight
Wow what entertainment. Both the poster and the bobint17 don't have a clue how this flashlight works... why answer a question you don't know the answer too? To screw with people? To sound like you know what you're doing?
Anyway, the Gerber TX 3.0 uses a Luxeon 3 LED. There is no bulb. It is not designed as a user replaceable item and unfortunately even someone skilled at soldering and such can't fix the light because the head is permanently attached and not designed to be removed allowing access to the LED assembly. Can the head be removed? Possibly. Will it damage something while trying to remove it with a lot of force? Possibly. Should you try? No. Why? Because the light has a limited lifetime warranty from Gerber. Send it to them and they will fix or replace it!!!
Feb 16, 2009 | Gerber Blades Gerber TX 3.0 Tactical...
Changed the batteries......now can't get it to work.
if you cant even put the batteries in, how am i going to teach you to code it? there is diagram in side case showing PLUS up or down, follow it. both go in same way, why would you put neg to neg. do yu do that with flashlight batteries. come on.
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Leeds Garrity 3AAA LED Flashlight - K9 36: $17.31 Logo
147 people viewed this question
Top Leeds Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Leeds Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
