Question about Kenmore Washing Machines
80 series, vibrates badly during spin cycle. - Kenmore Washing Machines
    Genius:
  • Kenmore Master
  • 1,585 Answers
Check bearings
Posted on Apr 21, 2015
Kenmore 80 series spin cycle isn't spining water out
could be defective part or lid switch problem
Dec 10, 2013 | Kenmore Washing Machines
High pitched sound during spin cycle
That machine doesn't have a belt. It is more likely that you have a bearing going bad. You may also have a tub seal starting to go which then leaks water onto the bearing, damaging it.
Mar 07, 2010 | Washing Machines
I have a Kenmore Series 80 washer and the tub
i would check the motor coupler
it sits behind the motor before the transmission
this model
thre piece part that drives the transmission
Oct 15, 2009 | Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Excessive vibration in spin cycle
Be sure the washer is on a solid surface, no plywood or skid platforms. Then be sure to lock in the front levelling legs.
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Washing Machines Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
