Question about Ryobi Garden
How to fix a ryobi 132 r electric string trimmer?
Won't go at all. Looks like there's plenty left on the brush, unless it's just failed to advance.
SOURCE: ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
Posted on May 31, 2008
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
AUTODOC01
  • 216 Answers
SOURCE: I need to know how to load a two string trimmer
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Posted on Aug 25, 2009
mrgauge
  • 17 Answers
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Posted on Oct 01, 2009
Testimonial: "Thank you! Just what I needed."
SOURCE: how do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
Posted on Oct 14, 2009
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
I changed the string in my ryobi 725r and since then it feeds the string so fast it wraps around the shaft. What did I do wrong?
multiple failures with bump advance string trimmers - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Jul 5, 2008 - I have indeed hurled my own ryobi across the yard in a fit. ... Some heads are not designed for curved shaft trimmers or on engines under a .... the fence so thestring won't wrap around the fence instead of whipping in and out.
Sep 30, 2015 | Ryobi Garden
I purchased an 8 inch heavy-duty brushcutter blade for my Ryobi 30 cc four cycle powerhead how do I attach it to the string trimmer head
You can't use the blade on most string trimmers unless you have a brush cutter style then you would unscrew the trimmer string head and attach the blade with the adapter that came with the unit.
Oct 23, 2014 | Garden
Why is my ryobi 18 volt trimmer smoking? I have had this 2.5 years and using it on lawn edges only.
The motor is failing. Most likely the brushes have failed, but this is all sealed and they cannot be replaced alone.
Jun 10, 2014 | Ryobi 18 Volt 18v Cordless String Trimmer...
What is the spark plug gap for a Ryobi string trimmer model RY30550 ?
No need to gap from a new spark plug unless the plug was dropped on the electrode.
May 02, 2014 | Ryobi Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
The electric motor on my Ryobi 137r string trimmer is vibrating, rattling, and has lost power. It sounds and feels like worn out (binding?) motor bearings. Are they available as a replacement part? What...
You likely are spot on with the diagnosis of bearings. But, I would hesitate to say that they are replaceable. Contact a local electric motor shop (alternator, starter, etc) to see if they would be able to change the bearings, and perhaps the bushings as well.
Jun 25, 2010 | Ryobi 15" Electric Factory Reconditioned...
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
Garden Logo
43 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
