Question about Bell Microproducts Computers & Internet
Building a 3D Ultra-HD Double layer Blue Ray DVR Server system to a HAMMER Z-Box HZD4B w/4-1TB WD 64MB Cache 6.0/3.0Gbps 7200rpm 3,5 Serial ATA SATA drives. Any Advice?
I am setting up an Intel Nobilis server SE7210TP1-E TPS Win7 Pro, 2-1TB WD 32MB 7200 Barracudas. Intel Legacy SL7E4 530/J processor E7210 Chipset, Integrated ATI RAGE XL/8MB/SDRAM Embedded Winbond:W83627HF-AW I/O LPC bus controller. 1GB Ethernet LAN to HAMMER Z-Box HZD4B w/4-1TB WD 64MB Cache 6.0/3.0Gbps 7200rpm 3,5 Serial ATA SATA drives
SOURCE: qwanum guardian 4400 server type 480 GB
Thanxx,
I tried hyperterminal it works very good and i see my computer starting up it works very good.
The problems i see now are that there is no Guardian OS installed on the drive.so the system is looking for an OS he cannot find it and the system hangs,
Do someone know how i can get Guardian OS to install?
Thanxx
Posted on Dec 31, 2007
CosmaP
  • 409 Answers
SOURCE: Can´t use INTEL SS4000-E to host the files of my database from SQL SERVER 2000
The SS4000-E  is a NAS storage server.  To the best of my knowledge it is not possible to put database files on a NAS.  They need to do on Direct Attached Storage.
Posted on Oct 22, 2008
joecoolvette
  • 5660 Answers
SOURCE: graphics card for D 101 GGC intel mobo/2.66/p-4/ram 512
I appreciate your taking the time to list the motherboard specifications. I also downloaded the Motherboard Manual from Intel.com, for the Intel D101GGC motherboard. (PDF version)
Now we know this,
1.You have a PCI Express x16 graphics expansion slot, for a graphics card.
It is the PCI Express 1.1 version technology that is used.
2.The motherboard chipset, (Northbridge/Southbridge chipset) is the ATI Radeon Xpress 200.
What I don't know is what your intentions are graphics wise. What you expect from your computer graphics.
I would recommend a VisionTek Radeon HD 3650 OC
[1GB of GDDR2 graphics ram. 128bit memory interface, with 120 Stream Processors]
(Not advertising for any particular computer parts website, but Tigerdirect and Newegg has this graphics card for around $50 U.S.)
The VisionTel Radeon HD 3650 is an ATI product just like your motherboard chipset.
(AMD owns ATI now through a buyout. It is now AMD ATI)
Using a graphics card based on the same technology as the motherboard chipset, is a recommended option. It IS NOT a necessary thing, but they 'Play Well With Each Other'.
The one thing of concern here is your power supply.
If I were to take an educated guess, (Based upon over 20 years of experience in this area, {Computers), I would guess that you have a 250 to 300 Watt power supply. (And a 12 volt rail with the capability of 18 Amps)
The Radeon HD3650 has a power supply requirement of 300 Watt, or greater power supply.
You'll be okay though.
Why?
Because this power supply requirement is based on a test computer system. The test computer uses computer components that require a Lot more power, than your installed components. This way the graphics card manufacturer is covered.
Do know that as time passes by, components inside a personal computer power supply, break down. Especially, if inside the computer isn't kept clean on a regular basis. You may want to look into a decent, reliable, 400 Watt power supply in the near future.
Sorry this solution is so long in length, but it couldn't be answered in a few short sentences.
Posted on Sep 06, 2009
  • 68 Answers
SOURCE: Intel Entry Server Board S3000AH
does the server board have onboard video? typically server boards will make use of on board vga and if this is the case you will need to go into the bios and enable either agp or pci-e as your first choice of video support. also make make sure that the bios revision on the intel board is current and upto date as there have been problems with server boards causing random issues.
if this fixes the issue please rate my answer accordingly.
regards
Posted on Sep 14, 2009
miokitty
  • 17 Answers
SOURCE: Can't map network drive WD Blue ring edition
The Failed Mount issue is usually caused by Internet Security settings. The most common way to resolve it is to add the following files/ports to the exceptions list of your firewall(s) -- in some cases you will need to add it to the Windows Firewall, even if you have another Firewall installed as well:
MioNet.exe (C:\Program Files\MioNet\jvm\bin\MioNet.exe)
MioNetManager.exe (C:\Program Files\MioNet\MioNetManager.exe)
ServiceStatusGui.exe (C:\Program Files\MioNet\ServiceStatusGui.exe)
These ports are also required for MioNet to create a drive-letter for remote drives:
TCP In/Out 443
TCP In/Out 445
Posted on Sep 18, 2009
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
I asked this a few days ago; , I have a Samsung SpinPoint P80 SP1604N 160 GB Hard Drive in a HP compaq presario SR 1617CL I want to replace it with a larger HD, 500GB or 1TB. Can I replace it with a...
Yes, either of these drives will work. The cache is not all that important it is just where data is stored temporarily in case you have to access it again soon after a file is written to the hard drive. The best thing you could do in this case is see if your motherboard has a sata connection which I would assume it does and buy a sata hard drive. It will be much faster than either of those drives, just make sure you also get a sata power adapter if your power supply doesn't already have one and a sata cable.
Mar 11, 2011 | HP Compaq Presario SR1620NX...
I have a hzd4b with 4 1-tb drives all new. I try to connect to the box to initilize the system but cannot. I believe the firmware is loaded on the hard drives them selves like the buffalo nas solution. ...
petrykja,
I have the same issue as you. I bought an encloser to hold my drives (that i already owned). My firmware is showing 0.38 so I don't think the firmware is housed on the hard drive. However, when I try to upgrade the firmware it says that it can't find the drive to load from. So I think the firmware is first loaded to one of the drives and then to the motherboard. Not sure. Any luck with this wince December?
-Chubby
Dec 29, 2010 | Bell Microproducts Hammer Z-Box HZD4B-1000...
I bought a "My DVR Expander" to use with my DirecTV HD DVR. Does Western Digital make this expander in anything larger than 1TB? If so, where can I buy one?
Note that your DVR will treat this as "extra" storage, i.e., supplemental to its "internal" storage.
A 1 terabyte hard drive allows you to record:
  • Up to an additional 600 hours of Digital TV
  • Up to an additional 120 hours of High Definition TV
Since the largest EIDE/PATA disk-drive is 0.5 TB, the disk-drive inside the Expander must be a SATA disk-drive.
So, disassemble the unit, disconnect the SATA disk-drive, and pay about $300 to buy a "2000Gb Western Digital Caviar RE4 Raid Edition 7200RPM 64 Mb Cache 3.5 7200RPM 64 MB Cache SATA Internal HD 3 Yr Warranty WD2003FYYS".
Connect the disk-drive to its interface.
Close-up the case.
Connect your "custom" PVR expander to your DVR,
and see if your DVR will recognize the 2TB of disk-storage.
Sep 08, 2010 | Western Digital My Book Essential Edition...
Hard Disk Problem
it seems as serious disk drive error to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter> then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job> this should fix the trouble, if not please send message
Oct 09, 2009 | Computers & Internet
IDE vs SATA
Sata is better hands down. Its the newer technology. I would keep the ide harddrive for media storage and such. You not going to notice the rpm differance to much. But the communication between board and the drive is faster with sata
Aug 27, 2009 | Computers & Internet
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
561 people viewed this question
Top Bell Microproducts Computers & Internet Experts
David Payne
David Payne
Are you a Bell Microproducts Computer and Internet Expert? Answer questions, earn points and help others
