Question about Whirlpool Refrigerators
Whirpool ice machine not getting water
I have a Whirlpool french door refrigerator that is only two year old. The ice machine stopped receiving water one day. I can hear the ice machine lever running all the time so I know the actual unit is working, but I no longer hear the water filling the trays. I've tried to take the ice machine apart but it must require special tools because I cannot access anything. The water dispenser on the front of the door does work just fine, however. I unplugged the refrigerator for 3 days to make sure it was not a frozen water line. Upon turning it back it, it still did not work. What would cause the ice machine to stop receiving water?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
If your certain the line isn't frozen. Then your valve is bad
Posted on Apr 21, 2015
Ice maker not working on a whirlpool french door fridge
Is the cold water dispenser working? If not, does the filter need to be changed? Do you actually have water supply to the fridge?
Is the Ice bin empty? Is this your fridge, or are you renting and this was in place? If yours, do you have an Owner's manual with the troubleshooting tips? No manual, try manualslib.com Make model possibly year and serial number. If not yours, there should be a switch that turns the Icemaker on or off. A green light on the front of the drive mechanism near this switch should mean it does have power. No light, no power. There should be a mechanical switch that stops the Ice maker. If the bin is empty, the ice detection arm should be down If it is not down, It is stuck in the "bin is full" position. If these are not the problem, It may be the electrical valve for the Icemaker water supply is not operating, or has been disconnected, or is bad. I have found that one of the online "appliance parts store or sites" have been quite helpful in diagnosing problems and recommending parts and how to fix.
Apr 01, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
It quit making ice - water comes out the water side--the dispenser works until bin is empty
some ice makers have an arm on them that stops producing when the box is full and sometimes it sticks in the ff postion
Mar 10, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
Why Icing on bottom freezer
Your drain hose in the bottom back of the freezer is clogged and Iced up and all the defrost water is staying in the freezer and building up. You need to take the freezer back panel off, remove all the ice, defrost the drain, clean, flush with hot water and test the drain line to reach the drain pan under the fridge.
Aug 18, 2014 | Whirlpool Whirpool 26 cu. ft. French Door...
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
My Whirpool ref. stop making ice. There is water
feed valve most likelly cause remove wtr. line if water comes out water valve is somthing to look at if it has power
Jan 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Ice Magic Plus not make ice at all.
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out(beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice maker is not working
hi. thanks for the question. because the door was left open . moisture got into the small tube that lets water in to the ice maker.. and froze. use hair dryer to thaw the tube. remove and clean. thanks the appliance doc. please rate me
Sep 11, 2008 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
88 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
