Question about Fedders Heating & Cooling
My friend has a Fedders PTAC unit from 1979 that died. No surprise there. However, I have had difficulty matching it to a new one.
Model: CMEA110C7D Serial: 267246 208/1Ph. Dims approx 26 1/4 wide 16 high 23? deep. Anyone know a match for this unit or has replaced one? I have an hvac business but I do central and my ptac sources were not 100% certain. Was recommended a Fedders MX match from Islandaire but not sure it is deep enough. Thanks! Evan
bobotfel
  • 236 Answers
SOURCE: PTAC UNIT QUIT WORKING
If you have a clamp tester, operate the unit with the clamp tester and check the current reading. If the current reading is normal but the reset button is tipped then there is something wrong withe power plug reset button. But if the current reading is higher than the name plate rating then there is something wrong with the unit.
Posted on Mar 09, 2008
SOURCE: Zoneline PTAC short circuit
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
Posted on Mar 30, 2008
SOURCE: Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Posted on Aug 07, 2008
koolbreezes
  • 540 Answers
SOURCE: charging a ptac
Either or, they both are the same ends but different routes..
Posted on Sep 08, 2008
KLR Monkey
  • 22 Answers
SOURCE: Amana PTAC cannot be turned on.
sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Posted on Feb 01, 2010
Looking for replacement of Fedders model T1A10W7A (not sure if installed in a type a or b sleeve). Which model can I replace with?
I suggest that you measure the sleeve's dimensions and shop the a/c dealers. They should be able to match you up with something of comparable BTUs, but more efficient.
Aug 24, 2013 | Fedders AZ7A12W7A Air Conditioner
I have a FEDDERS PTAC/HP -07B/09B/12B/15B. It blows cold air only. NO HEAT!
First of all check your unit model has heater system. And then
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 04, 2011 | Fedders Heating & Cooling
How do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Jun 15, 2009 | Fedders AEQ07FBG Air Conditioner
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
Apr 26, 2009 | Heating & Cooling
Ptac heating problem
This is the service manual for this system. It might give you an idea on what the problem could be. Page 27 should be your area to start. There are two for the PTAC series. I'm not sure which one will pertain to you.
http://www.friedrich.com/downloads/PTAC_Service_P-Series.pdf
http://www.friedrich.com/downloads/PTAC_Service_PD-Series.pdf
Mar 22, 2009 | Fedders AED24E7F Wall/Window Air...
Circuit breaker
ngfam1
Happy to assist,
HOW MANY BTU IS THE AIR CONDITIONER?
And is it 110 or 220 line!
If it is using 110 or 115 volts like normal house current and it throws circuit breakers in your electric box,then you need to run a dedicated line just for the Air Conditioner!
Usually this happens to 110 -115 volt air-conditioners that are more than 12,000 BTU and do not have a dedicated electric line in the wall only for the air conditioner!
New air conditioners have a circuit breaker built into the units plug!
And I have seen some that throw that breaker to off frequently even if it's only an electric surge! Which it should not do!
if its the case and it's new, take it back to the store and ask for a different model, size, or brand!
Fedders had an 18,000 BTU/ 110-115 volt unit that did this with every single unit last year! I stopped selling that unit only!!
Ngfam1
PLEASE GIVE ME A GOOD RATING HERE FIXYA.COM BEFORE YOU SIGN OFF!
you can just use it as is as long as it survives!
Aug 29, 2008 | Amana PTH123B35AJ Air Conditioner
Greg
Aug 07, 2008 | Fedders AED24E7F Wall/Window Air...
Fedders window model A6Y12F2B "New Unit",,only 10 days in use! Just stopped working No Power To Master Panel Air Conditioner Not Working Fuse Panel/Breaker ok,Outlet ok,,power to plug...
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Jun 22, 2008 | Fedders Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
