Question about Garden
My lawn mower will only switch of if I pull the plug out.
    Sergeant:
    Champion:
  • 294 Answers
A wire is broken that goes to the stop switch or the switch itself is bad. (I am assuming you intended to say "I pull the spark plug wire off") I don't know what kind of mower you have but, if it has a choke, that will stop it too.
Posted on Apr 20, 2015
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
SOURCE: i have a ryobi lawn mower with a 6.5 hp motor. it
I am working on one now. Customer said "it doesn't run". Ok. So, after oil/spark plug/air filter replacement...it didn't have any gas getting to the carb. Took off the bowl, and on this 2005 lawnmower, the inside of ALL of the carb was covered with a white/chalky film. Looked like tiny rust barnacles over ANY metal surface available. Silty white stuff in bowl. Blasted it all w/carb cleaner. Still couldn't get primer to work, but after I sprayed a bit o' starter in the cylinder, it started well & kept running. Until I let the bar down. Needs a new carb. Will see what the customer wants.
Posted on Jun 04, 2010
Replaced the governor operator new ignition module new spark plug and I clean the rust off of the magnet on the flywheel and still no spark
Hi Bob, The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well.............. CHEERS..
How to test a solenoid....
How to test lawn mower solenoid
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
May 12, 2016 | Garden
Lawn mower wont turn off
Using an electrically insulated tool pull the spark plug cable from the plug.
Presumably the kill switch needs to be changed
Jul 19, 2015 | Garden
My lawn mowers won't shut off
that slider pulls on throttle cable an at the end the slider shorts out the plug at the points to ground. look for loose cable to ground slide.
Aug 17, 2014 | Garden
How to fix Mower cord stuck after hitting rock?
Pull the plug. MAKE SURE THE PLUG IS COMPLETLY REMOVED AND SEPARATED FROM THE MOWER!! Remove the cover with the pull start attached. see if you can turn it by the flywheel or the blade. If you can, you can just have the rewind repaired.
If not, then you have a probable bent or twisted crankshaft. Most likely not worth repair.
May 16, 2014 | Electric Lawn Mower
Lawnmower won't spark
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Apr 13, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Will not start have depressed primer button the
Is the spark plug good? Check to see if it is getting spark. Unscrew the plug and plug it in to the plug cap. Have someone pull over the engine while you watch the plug to see if it has spark.
Jul 17, 2011 | Toro Power Lawn Mower
I have a Toro Model 20070 Electric start Lawn mower. It will not start. I changed the plug and filter. I pulled the plug and there appears to be no spark. When I turned it over I saw no spark. I guess my...
check your mower for interlock switches that might interupt spark for safety reasons.
A chute switch or something like that. Check your owners manual for troubleshooting.
Unplug the keyswitch and try pull starting to rule out a bad switch.
If it still doesnt have spark you might need a new coil.
The coil is right under the recoil cover and are fairly cheap.
A set of hand tools and $30-50 for the part should do it.
Good luck and be careful.
May 03, 2011 | Toro Power Lawn Mower
How do I turn it on?
plug it in to the hydro cord and pull the switch lever
Apr 05, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
My lawnmower won't start
My first action would be to check for fire. Pull the spark plug wire and either snap an extra plug onto the wire, or pull the mower's plug and snap into the wire. Pull or try the key start, to see if the plug is firing.
If it's not firing, you'll have to look at other possibilities... eg kill switch or coil issues.
I hope this helps... Good luck!
Oct 22, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
