Question about Microwave Ovens
I need an instruction manual, it stopped heating up. I'd like to see if its the fuse but Im not sure where it is
  • Microwave Ovens Master
  • 3,960 Answers
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Posted on Apr 20, 2015
SAMSUNG MICROWAVE FAN STOPS WORKING. COULD IT JUST BE THE FUSE?
I would guess, I do not know for sure that the fa motor seized and blew the fuse, during the process the internal protection device on the fan motor opened giving you exactly what you are describing.
Nov 27, 2014 | Samsung Microwave Ovens
My delonghi ac925chs combination oven and grill work... microwave has stopped heating have noticed there is no light on in the microwave.and when i went to use it yesterday it would not heat in the...
Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
Sep 04, 2011 | DeLonghi Microwave Ovens
Im having a heating problem with my maytag microwave, and want to check the fuse, but how do i get to it.
not all microwave not heating is in the fuse,and remember the microwave is high voltage dont try to touch by your hand,use plier with insulation before removing the part.the fuse inside the microwave is 2 type, 1 power fuse if we have power no need to replace,the other one is HV FUSE that one is connecting in capasitor and magnetron,this like is small plastic tube with wire if you remove you can open it,check the small wire inside the glass if is broken or split its means this one is defective need to replace but if this one is ok but not heating the second problem (common) is magnetron,but much better call an service technician to check the unit if not the parts i said is defective to make sure and you get a warranty after service.
Jan 01, 2011 | Microwave Ovens
My microwave just stop running while trying to re heat . how im going to fix it. is their any reset button
in most cases the reason for microwaves shutting down without warning is the fuse. in some cases the fuse will fail at its own fault. to test the fault we would do a tollerence test on the unit. but the best way for you to test it is to replace the ceramic fuse with another of the same value. if the unit works then its a faulty fuse. if the unit blows the fuse then the unit has a fault in the power supply that needs to be repaired by a service tech.
best of luck
Aug 03, 2010 | Microwave Ovens
Whirlpool 3hler5437jq1 dryer blows fuse
that would be a shorted or "bridged" heating element .. thats replaceable by a repairman or someone familiar with electrical things ..
here is where you can order parts and instructions for your dryer
http://3hler5437jq0.theappliancepartswarehouse.com/
here is where you can purchase a service manual if you need more information .. ($10) ...
http://www.manuals-in-pdf.com/index.php?main_page=advanced_search_result&keyword=3hler5437jq1&forward=plist
Nov 27, 2009 | Microwave Ovens
It just stopped heating yesterday but the light
you say it has aloud hum to it? And everything works but no heat.Im going to give you a list of things it could be and you'll have to take microwave apart to do the work. Beforre you start get some small trays or pill bottles to put screws in. Make sure when you take a screw out you know where it goes back because all the screws may not be same length. First, You may have a blown fuse in the HV transformer primary circuit, The HV transformer is the largest thing you'll see when you take the cabinet of the frame.Second,bad connections for the magnetron filament the magnetron will have what looks like fins or louvers around it.look for bad wire connections. Third, could be a faulty thermal protector or fuse, More than likely its either going to be the HV transformer or the magnetron thats bad.
Sep 13, 2009 | GE XL1800 1100 Watts Microwave Oven
How to remove ge spacemaker 1400?
You can download GE owner's manuals and installation instructions here.
Aug 18, 2009 | GE Microwave Ovens
Just suddenly stop heating - can't find any microwave service.
Did you change the diode as well, if not you need to change it if there nothing wrong problem is a bad magnetron
Professional appliance repair in Los Angeles, California.
Aug 04, 2009 | Sanyo Microwave Ovens
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
