What exactly does "damaged key" mean? - Computers & Internet
    Guru:
  • 66 Answers
Broken
Posted on Jun 04, 2015
What does damaged key mean?
exactly what it says damage can be twist and or wear or bbroken fob
Apr 20, 2015 | Jeep Cars & Trucks
How do I reset the ProLock system?
Hi Carol , do you mean PATS passive antitheft system ? Locked up your car ,do you mean it won't crank over an start ?
The passive anti-theft system uses radio frequency identification technology to deter a driveaway theft. Passive means that it does not require any activity from the user.
  • During each vehicle start sequence, the ignition key identification code is requested by the vehicle protection anti-theft electronics.
  • If the key's ID code has been programmed into the system, the powertrain control module (PCM) (12A650) is signaled to enable the vehicle to start.
  • If the key's ID code is not programmed into the system, or if no encoded key is detected, then the powertrain control module is signaled to disable the vehicle.
The passive anti-theft system communicates the state of the security system to the powertrain control module via the J-1850 communications network data link connector (DLC). The powertrain control modulebased on the communications from the passive anti-theft system, will determine if the vehicle's engine is enabled to start. The passive anti-theft system differs from the active anti-theft alarm system in that the passive anti-theft system enables/disables the vehicle from starting and only operates with the ignition switch in RUN/START position. The active anti-theft alarm system has perimeter protection capabilities and operates only with the ignition switch OFF. Refer to Section 13-11A for active anti-theft alarm system information.
Vehicle Disabling The passive anti-theft system will be activated and disable the vehicle from starting if any of the following conditions exist:
  • damaged encoded key
  • unprogrammed key
  • non-encoded key (key has no electronics)
  • wiring concern
  • transceiver concern
  • Passive Anti-Theft System (PATS) control module concern
  • J-1850 Communications Network concern
  • Powertrain Control Module (PCM)
Apr 15, 2015 | 1995 Ford Taurus
My keyboard works except some keys are not working?
Your question is not specific about specifically which keys work and which keys do not work and exactly what you mean by the keys not working, whether you mean there is no reaction at all when the relevant keys are pressed or whether it is just that incorrect characters result from pressing these keys.
If incorrect characters result from pressing certain keys towards the right of the keyboard, use the Fn key, bottom left, pressed simultaneously with the Num Lock key, top right, to toggle 'on' or toggle 'off' the Alternative Symbol function of some of the multi-function keys.
If there is no reaction at all when you press a significant number of keys, then there may have been liquid spillage damage to the NetBook. Liquid spillage damage can sometimes be resolved by partial disassembly of a NetBook/Notebook and wiping congealed liquids off with mild solvent or allowing internalized water to evaporate. This type of repair is best done by an experienced NetBook/Notebook repair center or technician.
If only one or two or a small number of keys do not work, then it might be that particles of some or other substance, trapped underneath the keys might be interfering with the function of the non-functioning keys. This can sometimes be resolved simply by inverting and gently shaking the NetBookso that any trapped particles come loose and fall out. Occasionally, individual key caps have to be removed and replaced after the obstructing particle has been removed.
If several keys are defective but the fault was not caused by liquid spillage or trapped particles, then the keyboard unit itself might be faulty and need to have its internal ribbon cable and cable connectors tested for cable damage or connector damage (typically either from liquid spillage, shock caused by dropping the computer or by previous unprofessional internal repairs). If no fault is found with the cable or the cable connectors, then the entire keyboard unit may have to be replaced.
Nov 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
5.5 B&S will not start. Flywheel key was damaged
Only the adjustment of the valves, if this is an OHV engine. You may want to check the "air-gap" on this engine (that is the exact distance between the ignition coil legs and the magnets in the flywheel). Here is a Briggs Check chart that has all those specs for your engine listed.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Aug 13, 2011 | Briggs & Stratton Garden
Disk won't come out of disk drive. What can I do?
on your laptop turn the system off first then as soon as you turn it on kee on tapping f2 to get to your system BIOS "Note: getting into the BIOS depends on the system Some require to press Delete Botton to enter the BIOS setup" once in the BIOS you can eject you DVD rom from there by pressing one of the function keys on your system this depends on what brand of laptop you have some have F10 to be the eject Botton in BIOS for all DVD/CD-roms to make it eject, also if the Functions botton dont work try Holding down the FN key as well + the function Keys try this one at a time till your cd/dvdrom is ejected, am sorry I cant give you the exact info this query is based on machine type and brand. but this should do it for you if it doesn't this means that your dvd/cdrom's mechanism insdie is damaged or malfunctioning. i do not suggest prying it out, ths may damage the system as well.
Jun 29, 2010 | Computers & Internet
Keys are locked. some keys work but keys U , J
I think filter or sticky keys enabled.
Go to Accessibility options in control panel and disable it.
Hope this helps.
Siju.D
Oct 29, 2009 | Dell Inspiron 700M Notebook
Where is underscore on labtec keybords
it is near to backspace key. exactly to say second key befor the bckspace.
Apr 19, 2009 | Computers & Internet
Igniton
Do you mean the steering lock? You should be able to push the key in while moving the bars a little until the key turns, if you mean the steering lock. You have to move the bars while gently turning the key to find the exact spot where the key will turn. Good luck...
Nov 20, 2008 | 1999 BMW R 1100 GS
Error code
hi,
this is a problem in scaning lamp,check the cable which is connected from scaning lamp to pcb is damaged or discontinued ,so replace it but the fault will be rectified replace the pcb,then contact service dealer
Oct 16, 2007 | Toshiba e-Studio 161 Copier Copier
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
