Question about Hitachi 42HDT79 42 in. Plasma Television
Where do I attach audio output for headphones.
Please display the location shown in owners manual provided with product in packaging
  • Hitachi Master
  • 5,631 Answers
Excuse me brother, but if you have the owner's manual and the TV set in front of you, actually you are in a better position to find audio output. I don't have YOUR manual. Anyway, you can download one from the link I'll provide you, maybe it is more explicit then the one you have
Look at REAR panel and search for word "AUDIO OUT". If the plugs of your headphon won't fit AUDIO OUT connections take it a photo and go to a computer parts shop with your headphones ans purchase the appropiate converter
http://www.hitachiserviceusa.com:8080/55HDX99.pdf
Posted on May 10, 2015
I receieved a pair of Koss SB145 headphones without the instruction manual. It has two connectors and I am clueless how to record things etc..
I suspect that you actually have the Koss multimedia headphone/microphone model SB/45 as shown on the right earcup, not SB145.
If this is the case, the 3.5mm connector with the black plastic (contains a headphone symbol molded into the plastic) and red insulation bands separating the conductors is for the stereo headphones. The other 3.5mm connector with the tan plastic (contains a microphone symbol molded into the plastic) and black insulation bands is for the microphone.
You need to plug these into the microphone input and headphone output connectors on your computer or whatever device you are recording with. Then adjust the microphone input audio level and headphone output audio level on your recording device. Consult your manual for your recording device to locate the correct connectors and for instructions to adjust the audio levels.
Also, be sure to check and adjust the volume level control on the headphone cord if you don't hear anything after correctly connecting them to your recording device and adjusting the levels.
Aug 14, 2011 | Audio Players & Recorders
Where is the headphone socket on a LT24M3
This is a link to the manual.http://www.haier.com/admin/en/product/upload/LT24M3-UM.pdf
On P.08 it shows the input and outputs. This television does not have a headphone jack. It has a digital audio output which is the SPDIF output.
To use headphones with the television you would need to get a digital to analog converter. Something similar to what is shown here: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=180-998
You would also need a digital audio cable (SPDIF cable). They are about $15-$30 depending on where you get it and the brand.
You would connect the SPDIF cable to the television output and the digital to analog converter box (DAC), and connect the headphones to the DAC box.
Feb 14, 2011 | Televison & Video
Beautiful picture,no sound
Hello
If your TV displays good picture and there is no sound output from it, please connect an earphone or headphone to its headphone/earphone socket, if provided, and check whether the sound output comes from it or not. If there is sound output from the headphone socket, and not heard from the speaker of your TV, the speaker inside your TV may got damaged. Check the speaker of your TV. For that you have to open the TV. Unscrew it and go for the same type and number and replace it. There is an other possibility, that is if your TVs headphone socket itself can got damged. You can make sure it by after checking your speaker. If the speaker is alright; the socket is faulty. Replace it with same type.
An other fault can occur is Audio Output Ic failure. If it has damaged, you won't get sound output either from speaker or from the headphone socket. You can make sure about it. Keep your ear very close to the speaker side of your TV, switch on the power to TV. If there is a "Thumb" soud is heard, you can make sure that your TVs speaker is Ok, and if there is a "Hum' sound also comes from it, Output Ic is damaged.
If so you have to open your TVs back cover and locate the Audio Output Ic. It can be located by following its speaker wire. The speaker wire goes to Output Ic. Usually it may be screwed into a metal heatsink. Desolder it out of the board, and go for the same type and number. Replacing it will solve the problem.
All the precautions must be taken before opening your TVs back cover. Plug it out from the wall socket bfore doing this. Keep chldren away from you, and not let them even stand beside you. Let an adult be there beside you as a precationary measure.
Read and understand well the above said solutions and go on.
Wish you sucess.
Oct 23, 2010 | RCA 27V514T 27" TV
Do i need to use HDMI wire if i have a cable box ?
It depens on what the cable box outputs are, you need to see if it has RF Coaxial jack (use CH3 or CH 4 on the TV), composite video out (Yellow RCA jack) with red and white RCA for audio, component video outputs (Red, Green, and Blue RCA jacks), or HDMI output jacks. HDMI and component video are for HI-DEF if you subscribe to the HI-def package. The cable company should provide you with the owner manual. Please post back with more info.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 16, 2010 | Dynex DX-LCD37 TV
When i tried to use any Msoffice applications it displayed a window! it asked for 25-bit product key!i tried the key which was provided to me! stil it displays a error msg that "Product key incorrect"....
The product key is either provided in the packaging material for the MS Office software, or it may be on the license agreement document in the package. If you purchased the software "used" ... it may be possible that the original owner has installed it (previously) and used the product key already (a couple of times or more). Hence, the key is no longer valid.
Aug 11, 2010 | Computers & Internet
No Audio device output installed
You must be using windows vista.
this error means you do not have hardware for sound.
if you are having this problem in desktop attach one headphone or speakr and it will work fine.
if you are using laptop try connecting headphone in jack it should work fine
Sep 29, 2009 | HP Computers & Internet
My sony dav-s-400 system keeps activating headphone port output.
Just had and fixed the same problem that hundreds of people are suffering with this system!!
Sony DAV s400 - same problem, won't play though speakers and display indicates that headphones are plugged in - when they are not. Fairly easy to fix and took me less than an hour from start to finish:
1) Remove top cover
2) Remove circuit board that has Audio In/Out phono scockets (to get access to Amplifier Circuit Board)
3) Remove Amplifier circuit board (has the speakers attached)
4) Turn it over and remove copper heat shield
5) Resolder joints where the big brown capacitor is and where the wires go to the front headphone socket...and any other dodgy joints that you find
6) Reassemble.
Feb 03, 2009 | Sony DAV-S400 System
Hitachi 42HDT79 42 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
