Question about Sony BRAVIA KDL55HX750 55-Inch 240Hz 1080p 3D LED Internet TV, Black
Tv plays about 2 minutes and picture and sound goes off, comes back on.Does this 3 times then tv shuts.turn tv back on and repeats sequence.
    Habit-Forming:
  • Sony Expert
  • 167 Answers
There is main board defective please replace the main board 3 time blink is dc alert which is happened in side the system ic & we cant replace the system ic so we replace complete main board
Posted on May 07, 2016
TVtechmaniac
  • 140 Answers
SOURCE: losing picture
Six blinks error code could be the Thermal Fuse part# 1-910-006-44
Posted on Sep 28, 2007
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Posted on Mar 24, 2009
SOURCE: TV turns off/on
I had the same problem on my TV (had it for 2.5 years) tried to clean the bulb, but it still did the same thing. So i replaced the blub and the problem went away and the screen is brighter now. Sometimes it just about that time to replace the blub anyways.
Posted on May 05, 2009
  • 5 Answers
SOURCE: Tv shuts off after a couple minutes then stays off for a couple minutes then process repeats..
Has the tv been getting dim? If so it's the lamp. Mine did the same thing.
Posted on May 11, 2009
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
Mar 30, 2014 | Envision L32W761 32 in. LCD TV
Tip
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
FALSE!
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi ws65713 picture goes out
I know these sets well, you lose brightness but still have sound?
If the green power light comes on for a few seconds and then goes out the set has a self check for error codes:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 02, 2012 | Mitsubishi Televison & Video
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
Jun 03, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
I have a Mitsubishi big screen tv model #WS-65857 and the picture went out as though the tv was turned off and when you turn it back the green light comes one for about 5 seconds the goes of there is no...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
if your set does not have a device button press Menu and Input together for 5 seconds and release. there will be a pause between blinks---2 blinks, a pause and two more blinks etc.
If you need help: etower.766@netzero.net
I do this here for free so if this has helped you give me a vote here.
Aug 18, 2009 | Televison & Video
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
Sony BRAVIA KDL55HX750 55-Inch 240Hz 1080p 3D LED Internet TV, Black Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
