Question about Mitsubishi Televison & Video
My Mitsubishi he 1080 series ws65313 won't stay on when I try to turn it on I see green on light then it turns off I need help please....I've tried to unplug it for 5minutes but it still turns off
  • 1694 Answers
SOURCE: TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
www.Chris@ChrisAndNat.com.................T.
Posted on Nov 23, 2007
SOURCE: My mitsubishi VS-50707 won't turn on
is it a projection
Posted on Mar 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 29, 2009
SD Tech
  • 14553 Answers
SOURCE: Constantly blinking green light
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD TECH
Posted on Oct 11, 2009
SD Tech
  • 14553 Answers
SOURCE: power will not stay on
Based on the model number WS65511, this set has a self check.
Turn on and when green power light goes out:
On the front of the set press and hold BOTH the MENU and INPUT buttons for at least 5 seconds and then release both buttons.
Power light will blink a two digit "error" code.
The most common is 2 blinks, a pause and 2 blinks. Set will repeat the error code at least 5 times.
Let me know what error code you find and I will tell you what it means, I hope you find it is 2,2 as that is the most easy to fix.
SD TECH Steve
Posted on Jul 14, 2010
I have a Mitsubishi HD 1080 series and it will not turn on. Does that mean I need to replace the bulbs?
The model indicated here has a self check if the green power light comes on f o r a few seconds and goes off, do you get the power light briefly or not at all?
Aug 27, 2012 | Mitsubishi WS-55805 55" Rear Projection...
Every time I turn my HD 1080 series Mitsubishi on 2 1/2 seconds later it turns off by itself
ok, a model number would be helpful but:
when set turns off and green power light goes out: on the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and let both go.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
This is the error code and indicates where the problem may be---let me know what code you find and I will tell you what it means.
SD TECH
Apr 28, 2012 | Televison & Video
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Mitsubishi 1080 diamond tv screen turns off
Your tv has a lamp inside (refer to your user's manual) make sure is in good condition.
Mar 21, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
My 2001Mitsubishi 1080 hd Won't come on
Most Mits. models like yours will need a DM module repair or
replacement----either way, about 600.00.....T.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
