Question about Samsonite Photography
I forgotten samsonite lock number. how open lock
    Master:
  • 992 Answers
I am sorry to say that if you don't know and cant afford to try the numbers in turn, you are stuck needing another way to get in.
Posted on May 11, 2015
SOURCE: samsonite attache case lock
I just used the following solution successfully...
thanx to whomever posted it.
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
Posted on Apr 10, 2009
  • 91 Answers
SOURCE: My Samsonite suitecase is open, I forgort my lock
look behind the lock
there is a tiny part (like a stick shift) sticking out of a square about 1 cm across
move it to the diagonally opposite side
reset code
return shift to old position
For those without the little stick shift part, try this: With the case open, and the current combo in place, hold down the shackle (the little grey or black button beside the combination numbers).
While holding this shackle down, rotate the numbers to the number YOU WILL REMEMBER.
(Holding the shackle down allows the numbers to tumble without moving the divots.)
Let go of the shackle -these numbers are now associated with the divots.
Now your combination should be set to the number you wish.
Hope this helps,
Karlos
Posted on Jul 04, 2009
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
SOURCE: my samsonite hardcase luggage's centre no.lock not able to close
problem sloved
Posted on Oct 21, 2009
SOURCE: forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Posted on Dec 10, 2009
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
I have forgotten combination tomy suitcase and it is locked how can i get it unlocked
Start at 000 and go up one number at a time until it opens or reachest 999.. it will take some time. .. good luck.
Dec 01, 2014 | Samsonite Silhouette 11 Hardside Spinner
Roncato suitcase forgotten my combination and cant open the suitcase
I have a Roncato hard shell with a 3 digit combination lock under the handle. I set the combination YEARS ago, had a young child play "horsey" on it, and turned all the numbers! The suitcase was locked and I had forgotten the combination. I followed the instructions in answer 2 above and it worked! I didn't have to add or subtract 5. I used a small sewing needle and a strong flashlight - the indentations were easy to see.
Feb 11, 2013 | Samsonite Photography
Samsonite breifcase combanation lock
I cannot open my manual lock & I have forgotten the number
Sep 19, 2012 | Samsonite Breifcase
How to unlock samsonite combination lock?
1. Call Samsonite Customer Service at 1-800-262-8282. Representatives are available Monday through Friday from 10:30 a.m. to 5:30 p.m EST.
2. Press "1" and then "6" on your telephone keypad to speak with a representative to order a replacement key or padlock.
3. Pay the required fee. Samsonite will then send out the replacement key.
Aug 17, 2012 | Samsonite Tsa Acceped Padlocks Allow You...
Reset lock on samsonite oyser luggage
i hope you can help me!
i went to change the combination on my locked Samsonite bag and when i closed it it would not open on that number.
i have tried the past number as well as the new one and it still doesn't open. thank you if you can help please it would be appriciated.
Carolyn
Jun 09, 2010 | Locks & Locksmithing
HELP needed to open combinaiton lock
side latches of my samsonite brei case is open but cant get the combination lock to release
Jan 21, 2010 | Samsonite Case & Tripod Kit for Digital...
Oct 16, 2009 | Samsonite Tripod
Forgot my 3 digit number lock on my samsonite bag
Sep 17, 2008 | Samsonite Tripod
Suitcase number locked combination forgotten
f'lite Samsonite combination lost and stuck locked:
I removed the lock unfastening the 2 torx screws from the case.
Next I removed the pin that holds the RED tab thingy in place and the spring ( all this does is pushthe assembly to the right when a number is moved..... Take a picture of this before you dissassemble it. push it allthe way through..if you have fat fingers you are screwed. Anyway, remove the red thingy, and then carefully lift the remaining plate out taking note of the orientation.
First of all: the solution is aligning the cogs to 0-0-0 like from the factory. This is easy to do. when you remove the plate above , carefully do so without launching the dials and the spring into space....no matter.
Look at the bottom of the plate and notice there is a notch that will correspond to the cogs still in place on the lock assembly that should still be in place.
The cogs sit on a spring that sit on the backside of the dials with the numbers you can see when locking the suitcase.
Here is the meat:
1. with your finger or something turn the cogs until the black dot aligns outmost.
2 align the cogs so that notch will correspond to the orientation on the plate you just looked at. (that's it)!
Carefully replace the plate with finger pressure and actuate the latch-it should be unlocked and at the 0-0-0 position. If not repeat 1 and 2.
Push the pin through again, through the red thingy and the spring. BAMMM! you just saved your self a zillion dollars...still having trouble...mail this to me and for $15. I fix it for yaz....
May 13, 2008 | Samsonite Tripod
Photography Logo
1,114 people viewed this question
Top Samsonite Photography Experts
timtak
Level 1 Expert
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
