Question about Bernina Artista 640E Sewing, Quilting and Embroidery Machine with Embroidery Module
I am ready to start up in the embroidery mode. the size and the stitch info is on the screen. the screen is blinking the start button. I push the button on the machine and nothing happens.
  • Bernina Master
  • 1,860 Answers
It's possible there could be something wrong with the computer, only a sewing machine repair shop can tell you for sure
Posted on Jun 03, 2015
4 Suggested Answers
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
SOURCE: Bernina 430 sewing/embroidery machineWhen trying
disconnect your presser foot.
Posted on Feb 12, 2012
  • 166 Answers
SOURCE: artista 165 embroidery unit will not communicate with my sewing machine.
Did it ever work ? Have you had the firmware updated in the machine - if-so, the V4.04 firmware will not communicate with a V3 embroidery unit and you'll have to get them updated to the same version. Failing that, I'm afraid one of them has a fault on the serial interface. Note also that a 165 sewing machine will not work with a 180/185 embroidery unit because the earlier unit has a 2MB memory internally, whereas the later unit has a plug-in 4MB memory.
Posted on Feb 14, 2012
Embroidery stitches to far apart
1. To make changes on a computer there is a method to increase or decrease the size of the embroidery (usually two buttons pushed simultaneously). This will resize the embroidery and compute a new number of stitches. If you have resized it in the past without utilizing this feature the number of stitches will be wrong and will make an embroidery that has problems.
2. The embroidery program that you are using may have a problem. This can be checked by trying other embroidery programs.
Oct 01, 2016 | Brother Sewing Machines
Position of Touch Panel.
It's been awhile, but I think you go into the test mode then hit one of the hard keys (start, threader, reverse). I know there is a backdoor for this.
On newer Brothers you touch the screen and hold while powering on, but I'm not sure yours does it that way.
Oct 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
I am trying to figure out how to monogram. I keep having trouble adjusting my machine.
For doing a manual monogram (by hand, not using embroidery unit) Follow these steps.
1. Put on the "N" foot ( This is your open toe foot, so you can see easier)
2. Select the zig zag stitch (Should be #4, right next to the straight stitch)
3. Hit the stitch adjustment button on the screen ( Lower left)
4. Set the width (Will have a zig zag "/\/\/\/" icon) to whatever size you would like (Usually 4.0mm to7mm)
5. Set the length (will have a line "---------" icon) to a very short setting
You're now setup for a monogram. You might like this video too for using your embroidery unit.
Let me know if you have any more questions,
Chris
Jun 07, 2010 | Baby Lock Ellure
Fix button won't work in embroidery mode
Just to make sure you know what "Fix" does in Embroidery Mode - you press it before you start your embroidery then when you press Start, the machine will baste a square or rectangle the size of your embroidery before moving back to the centre ready to start the actual embroidery. It is not used to Fix stitches in embroidery mode (like it does in regular sewing mode) and it must be used before the embroidery is begun if you want the basting. Is this problem you have? It will not do the baste stitch?
Jul 11, 2009 | Husqvarna Designer I
Not making stitch
a.gif Dear Joan,
On the top of the machine there is a button. Push the button while turning the handwheel toward you. When the button drops into the machine, you are ready to adjust the length. Keep holding the button in the machine and turn the handwheel forwards or backwards, noting the numbers on the inside of the handwheel. Turning the handwheel to the back decreases the size of the stitch, and turning the handwheel forward decreases the size of the stitch. Release the button and then begin to s
Apr 09, 2009 | Juki Sewing Machines
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
Bernina Artista 640E Sewing, Quilting and Embroidery Machine with Embroidery Module Logo
99 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
