I have a bush white washing machine and now it blinks all the buttons. What does it mean?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Unplug for 15mins and retry
Posted on Apr 21, 2015
Krazytech
  • 725 Answers
SOURCE: fitting "Bushes
you will have to remove the back then the motor then the motor brushes
Posted on Sep 06, 2008
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
ginko
  • 19396 Answers
SOURCE: what does error 5 mean
Hi.
Error 5 means that there is a water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water pressure switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Posted on Oct 29, 2010
  • 6277 Answers
SOURCE: Can you please tell me
If water is going in OK and there is some sort of action from the washer this is only a possible solution!
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 21, 2011
rickyrt441
  • 4399 Answers
SOURCE: have a bush hw60-1460d washing
Have you tried to unplug the machine? It may reset. The locking lid switch may be bad as well.
Posted on Feb 25, 2011
Bush washing machine error code 8888 what does this mean
Error code Err 08 The start/pause light, program ready light and program end light blink. The motor has failed. Shut down your machine and unplug. Turn off the tap and contact the nearest authorized service agent immediately. http://electronicshelponline.blogspot.com/
Jul 14, 2016 | Washing Machines
LG SteamWasher WM3001HPA start button blinking. What does it mean? What do I do?
Hello. Make sure the "child lock" hasn't been activated--it will lock the control panel functions. To de-activate it if on, press and hold the "prewash" button for at least 3 seconds. You will see the "child lock" become unlit in the display and the machine will work normally. Also, make sure the "delay wash" hasn't been activated--get your user manual and read the section on "delay wash"--you aren't the first--and definitely won't be the last user who has inadvertently set the delay wash feature! Let me know what you find. Thanks!
Nov 06, 2015 | LG / SteamWasher Series WM3001HPA
Hi. I have a Bush A126q washing machine, which last night, suddenly stopped working on any programme and with the start/pause light blinking. I have checked the usual suspects, pump filter, too much...
All Machines theses days are digitally controlled, which means they do a self diagnostic test just before they start. If a fault is found they usually just stop with the light blinking. To determine the exact fault the appropriate Engineer for the machine will come along with his laptop and do his test to find where the fault is. However the most likely cause of your problem if the machine is 3 or more years old is the motor brushes. Remove the motor from the machine then remove one of the carbon brushes, if its about 3ml long its worn out.
make sure before removing the motor that the machine is disconnected from the Electrical and water supply, makes it a lot easier.
Oct 27, 2014 | Washing Machines
What does it mean Bush HW601460D error 7 ?
I believe this is the fault when the motor bushes need to be changed. check the motor for black powder on / around it. this is a sure sign they are worn down.
Nov 07, 2013 | Washing Machines
Cant get Bush WM-1260TVEME washing machine to start a cycle off the button
Check to see if the power is getting to the machine. If it ismake sure the door is closed firmly, there is a safety switch on the door. If none of these things work, you have adoor switch problem or a panel fuse out or a broken panel circuit. If you have the skills to open and troubleshoot than those are the things to look for.
Jan 02, 2013 | Washing Machines
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
What does error 5 mean on the bush wm-1260tve washing machine?
Hi.
Regards.
Ginko.
Sep 20, 2010 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
