Garden Logo
F
Forest Butler Posted on Apr 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I adjust the valves and what do they set on
Handyman
Level 2:
  • Expert 125 Answers
  • Posted on Apr 21, 2015
Handyman
Expert
Level 2:
Answers
125
Questions
Helped
57729
Points
296
Under the valve cover. 6 intake 8 exhaust mm
How do I adjust the valve clearance on my 1989 Harley Davidson sportster ?
The Harley forums are full of great advice.
sportster valve adjustment
Harley Davidson Forums https://www.hdforums.com > ... > Classic > Ironhead
Sep 10, 2012 - Option 2: Adjust on the looser end of the range: Set the adjusting screw to finger tight so that you cannot turn the push rod between forefinger ...
Valve Adjustments - Harley Davidson Forums
Aug 21, 2007
99 Sportster 883, are valves adjustable?
May 11, 2010
Valve Adjustment - Harley Davidson Forums
Apr 21, 2008
valve adjustment on TC96? - Harley Davidson Forums
Dec 17, 2007
More results from www.hdforums.com
How do I tune a carberator on a 7.5hp mercury outboard
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
2answers
How do you adjust idle speed 1991 johnson 100 hp
not important, what's important is that they are absolutely clean, including the four brass high speed jets located in the bottom center portion of the carburetor.
That model engine's carburetors has fixed jets, BUT if the slow speed jets are adjustable, earlier model carburetors have been installed. If so...................
The four adjustable needle valves control the flow of fuel in relation to the set air flow, adjusted as follows (if needed).
(Dual Carb V/4 With 4 (2 each carb) Slow Speed Adjustable N/Valves)
(J. Reeves)
The adjustment procedure of the carburetor slow speed needle valves follows. NOTE... if the needle valves turn too freely, replace the nylon bearing retainer (the nylon item at the front of the carb that the needle valve goes through first) with the newer type RED retainer #315232. If your engine has that weird linkage that connects all four of those needle valves, the newer RED retainers will enable you to discard that linkage. The RED retainers make it impossible for the needle valves to vibrate out of adjustment.
(Carburetor Adjustment - 2 Slow Speed Adjustable Needle Valves, each carburetor)
Initial setting is: All (4) Slow speed valves = seat gently, then open 1-1/2 turns.
Facing the carburetors, start with the top left needle valve, then the top right valve, then the bottom let valve, then the bottom right valve. It may be necessary to redo these steps to get the adjustments ideally set
Do not attempt to gradually adjust all four of the valves at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Send the valve settings for a toyota 3L engine
Valve setting? Most engine valves have an automatic adjuster to self adjust the setting. You didn't say you had it apart. So, I'm thinking you have a dirty condition that would make the adjuster or valve tap. If so good additives just for both those conditions can restore the adjusting by cleaning and freeing the ailing parts. Try the link below for more info and needed product. Stops noisy engine valve tap in 10 minutes or free Add Driving ends tap
What is the sequence for valve timing adjustment IE when No 1 cyl intake is fully open which vale is adjusted ?? and so on
NONE you set valves with #1 cylinder at (TDC) both valves closed then you adjust that cylinder, follow firing order , roll motor over till #2 cylinder is at compression stroke and set valves and so on ,its best to do them one at a time .no mistakes
Valve settings
- Pull the hand brake and put transmission in neutral.
- Remove spark plug cords.
- Remove the spark plugs.
- Remove the Tappet cover
- Lift up the left front wheel.
Cylinder number 1 is toward the pulleys and belts side.
- Rotate the crankshaft anticlockwise with socket and extension rod and bring the valve tappets (intake and exhaust) No. 4 cylinder on dancing position.
NOTE: THERE ARE OTHER WAYS ALSO TO ADJUST THE FOUR VALVES AT A TIME. BUT AS DIY FOLLOW THE FOLLOWING METHOD TO AVOID ANY CONFUSION.
- Adjust the valve clearance of number 1 cylinder.
Valve clearance:
Intake 0.18 - 0.22 (cold) Exhaust 0.25 - 0.28 (cold)
- Rotate the crankshaft anticlockwise to bring the valves of cylinder 2 on dancing position and adjust the valves of No. 3 cylinder.
- Similarly rotate the crankshaft to bring the valves of No. 1 cylinder on dancing position and adjust the valves of No. 4.
- Rotate the crankshaft anticlockwise to bring the valves of cylinder No. 3 on dancing position and adjust the valve clearance of No. 2 cylinder.
2answers
Need help with valve adjustment specs
Exhaust power valve adjustment for "stock setting" is: 1/2 turn out from closed.
4helpful
How to adjust valves.
The intake valves set at .006 plus or minus .001
The exhaust valves set at .008 plus or minus .001
Remove the rectangular valve access covers at the top front and top rear of the cylinder head. With the engine cold, remove the spark plug. Turn the flywheel to TDC compression then place the specified thickness flat feeler gauge between the top of the valve stem and the adjuster on the rocker arm. Set the adjuster so that there is a slight drag when removing the gauge. There should be a valve adjusting tool set in your tool kit. It is a "pin" that fits the top of the adjuster and an open wrench to loosen and tighten the lock nut on the adjuster.
A “very helpful” rating for this answer? Thanks!
Top Garden Experts
Jay Finke
Jay Finke
john h
