Question about Sanyo DS32920 32" TV
My volume dont work on my virgin tv control
My volume dont work on my silver control could you get me the codes for a sanyo tv
  • 1,694 Answers
Re: my volume dont work on my virgin tv control
Contact the silver remote Mfr. or tell us the make / model of
the remote you have...............T.
OR for new Sanyo remote....
Please rate this solution..........
Posted on Nov 14, 2007
0 characters
3 Points
I bought a oneforall universal remote but need a code for a supersonic 1380
If you are a user of AT&T Uverse remote, your technician might have possibly programmed your Sanyo TV remote before leaving.
If your remote is not programmed you can easily program it by following steps which will be mentioned in the user guide, these include:
  • You must know the four digit code for AT&T Uverse which might have been given to you at the time of TV set up.
  • The remote control codes for Sanyo TV AVM - 1337U are 1045, 4062, 1095, and 1380.
There are different methods to make your Sanyo TV remote work. For example, if you have a black remote, press the zoom button which will be on the right hand corner of your TV. Then you will have to press fast forward for two seconds or till the time the TV shuts down automatically. Then once again switch on the TV and press zoom, your remote will start working once again.
In case you have a silver colored remote control, enter code 922, you will be guided to a menu. You must select RCA. IF code 922 does not work for you, enter code 1041.
  • Any of the codes mentioned in your user guide book will definitely work. Once the code is accepted by the TV, you can program it easily and set the channels of your choice.
  • While setting programs you can program it either the manual programming method or the code search method.
  • Device codes assigned to the TV will again be mentioned in the user guide booklet.
  • The Uverse remote control is a universal remote control which is user friendly.
  • These programmed remotes are configured to work with other audio and video devices too. Uverse also offers other services such as high speed Internet, cable TV service, home phone, etc. It's rated as the best service provider in the market.
Audi Air Intakes
Jun 07, 2012 | GE Standard (CRT) Televisions
What is my tv code for programming my dish network remote.
Welcome to FixYa!
You can use these codes to program the Dish remote control to your Sanyo DS32920:
542, 589, 590, 591, 592,609
You may also try Power Scan Instructions. Please follow the steps bellow.
1. While at the TV locations (TV1 or TV2 depending on which key is installed), point the remote at the TV. Press and hold the TV MODE button on the remote until all four MODE buttons at the top of the remote light up.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the TV turns off. This process may take several minutes.
4. Press POUND (#) on the remote. The TV MODE button will flash three times.
5. Press TV POWER on the remote to turn on the TV. Press VOLUME on the remote to confirm the remote controls the TV. If this does not work, return to Step 1.
Keep me posted.
Apr 07, 2011 | Sanyo DS32920 32" TV
Need codes where can i find them
To set up the volume control on your virgin remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
TV Codes
Akai 0236, 0544, 0630
Alba 0037, 0065, 0246
Amstrad 0205, 0440, 0065
Bush 0246, 0263, 0377
Decca 0064, 0100, 0544
Ferguson 0101, 0363, 0221
Fidelity 0244, 0221, 0460
Finlandia 0374, 0387, 0236
Goodmans 0065, 0064, 0100
Granada 0379, 0387, 0391
Grundig 0563, 0582, 0515
Hinari 0037, 0064, 0065
Hitachi 0253, 0384, 0377
JVC 0681, 0081, 0122
Matsui 0263, 0205, 0037
Mitsubishi 0136, 0382, 0064
NEI 0065, 0365, 0459
Nokia 0508, 0501, 0576
Panasonic 0678, 0254, 0278
Philips 0584, 0065, 0040
Saisho 0039, 0205, 0263
Samsung 0065, 0584, 0037
Sanyo 0236, 0073, 0100
Sharp 0121, 0064, 0065
Sony 0533, 0038, 0039
Tatung 0065, 0100, 0544
Thomson 0363, 0653, 0137
Toshiba 0536, 0063, 0271
If I have not listed your make of TV in the table above,
1. Press to go to the Home Screen.
2. Choose Telewest Services.
3. Choose Technical Assistance.
4. Choose TV Control Codes.
5. A full list of TV brand codes will appear.
If the volume control is still not working after trying all the codes for your TV model, or your TV model is not listed, then your TV is not compatible with our remote control and you will need to use your TV remote to control the volume as normal.
You can also use your TV remote control to adjust the volume in the normal way. Good Luck
Jul 27, 2009 | Standard (CRT) Televisions
Orion tv need codes for remote control.
I need help with remote control rca r5464 for orion tv
Dec 19, 2008 | Orion1934 19" TV
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Mar 17, 2008 | Sanyo DS27910 27" TV
Need tv code for remote control
¿Porque siempre preguntan por el codigo para el control pero nunca ponen el nombre del control y el modelo ?
Mar 17, 2008 | Sanyo DS19310 19" TV
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Sep 01, 2007 | Sanyo DS31590 31" TV
Manual Controls Insufficient
What is your universal remote control? if its not philips magnavox you try this universal remote control you will set the code match to your tv sanyo which you will see at the back of the instructions manual when you buy this remote control. follow the instruction of the manual on how to enter the code for tv. thanks.God bless you. i hope it will help.
Jun 11, 2007 | Sanyo DS20930 20" TV
Sanyo DS32920 32" TV Logo
107 people viewed this question
Top Sanyo Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Sanyo Standard (CRT) Television Expert? Answer questions, earn points and help others
