Question about Sewing Machines
Can't figure out how a properly threaded bobbin in the case is supposed to look. Pictures would be helpful. Thanks.
Singer 201-2
    Master:
  • 335 Answers
Please provide make and model.
Posted on Apr 20, 2015
  • ray gallant Apr 20, 2015
    Singer 201-2 at bottom of post
    Top Expert:
  • Sewing Machines Master
  • 52,096 Answers
The metal bobbin fits in a metal bobbin case that sits under the small sliding trap door left of needle the bobbin case has an ear that points UP and must fit into the slot for it
informatica
  • 1114 Answers
SOURCE: putting the bobbin back together
You can download the manual from the link below: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl3500t3510eus&type2=-1&flang=English&dlid= Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 76 Answers
SOURCE: Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Posted on Sep 03, 2009
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
I have a singer 201 knee control and I love it until today.
try these suggestions
rethread the machine top and bobbin, using every thread guide
try a new needle--one for the fabric being sewed--make sure the needle is inserted correctly into the needle holder
make sure the thread does not come off the thread take up lever
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
Oct 29, 2013 | Singer Sewing Machines
I have a Singer Confidence 7469. It has only been
The bobbin case is not supposed to move. It should only have a little bit of wiggle room so there is enough clearence for the thread.
Feb 18, 2010 | Sewing Machines
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed...
Nov 14, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Feb 07, 2009 | Singer 6423 Sewing Machine
Singer featherweight bobbin won't pick up needle thread
pull the bobbin case out by pulling tab or flapper forward (outward toward you) and take bobbin out of bobbin case, If bobbin has thread and that it is coming off bobbin free and is not hung up on bobbin case.
let me know if this helps you,
sec_duane@hotmail.com
Nov 10, 2007 | Singer Featherweight 140Q
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
