If it is a zx10r 05 model there is a rear plastic cover that is directly behind the rear passengers seat which also wraps around both sides of the bike to meet both side covers ,on the left hand side of the rear cover there is a key barrel that unlocks the rear seat ,but the key is barrel hidden and can only be seen by looking underneath and the key is inserted with the main plastic (black handle)bit facing toward the ground and the metal part of the key will be pointing towards the sky ,so you will have to sit on the ground to see it and look or feel under to find it and when you do it will remove rear seat so when you turn the key lift up on the front of the rear seat to remove it then you will see that the front seat is held down by a bolt .
