Question about Sears Garden
I d0 I get a wiring diagram or scamitic for my Sears tractor 917.272962
I need to trace the safety switches.
  • Sears Master
  • 1,169 Answers
It is so easier to just link OP to the owners manual.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0101121.pdf
Wiring diagram page 35.
Posted on Apr 20, 2015
  • Sears Master
  • 2,478 Answers
Your owner's manual has one.
    Master:
  • 335 Answers
Sears makes these available. Go by the store or do it on line.
Where can I find wiring diagram for sears tractor model 247-289010 ?
http://wiringdiagrams.soilwistaria.info/craftsman-router-wiring-diagram/
Apr 22, 2017 | Sears Garden
My Craftsman Lawn Tractor will not crank over,under normal means. Why?
First,WHEN was your valves adjusted? If out of adjusted the compressionl doesn't lease
Oct 17, 2015 | Craftsman Garden
I need a wiring diagram. I have a short in a wire or safety switch burning up wireing
trace the burn wire to where the problem is . any wire after that point will not be burnt.
May 08, 2015 | Garden
Replaced battery and will not make a sound
Troubleshoot as follows: 1. Using a set of jumper cables connect the Black side of the jumper cable between to the (-) of battery and a the block of the engine. Connect one (red) end of the jumper cable to the (+) of battery...And just touch the other end of the red cable to where to mower battery cable touches the starter. *Only tap it and starter should turn over. This bypasses all switches and wiring. If it does not turn the starter, the starter is likely bad. If it does turn over, check the starter solenoid, seat safety switch, blade engagement safety switch, clutch brake switch, or wiring in between those components. A wiring diagram would be most helpful. It came with the mower, or can be found online...likely at a sears/craftsman web site, but sometimes also at parts retailer website too. Similar bypass method can be used for troubleshooting. DO NOT OPERATE WITH BYPASSED SAFETY SWITCHES, ETC. Bypassing is for troubleshooting only.
Nov 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a wiring diagram for sears model 917.272066 riding lawn mower
Should contact SearsPartsDirect.com,they have all the wirings on all their Craftsman lawn tractors. There is another way you might find a wiring diagram. Look in back of your Owner's Manual,i have found a wiring diagram & part numbers to include,the whole tractor is broken down in a diagram format. There are other lawn mower shop that should have a wiring diagram,i.e. AMCParts.com. Hope this helps.Sincerely,Brad Locke DTD 12/04/15
Oct 27, 2012 | Sears Garden
Garden tractor shuts down when you PTO on or release brake
You have a safety switch or a relay malfunctioning. Try going to www.partsdirect.com, this is sears website. Look at the diagram to see how many safety switch on this unit. You may get lucky and replace one or you may have to replace all. I would look to see if it has a safety relay first, try replacing that first.
Sep 30, 2009 | Craftsman Garden
I need a wiring diagram for the ignition switch on a model#917255691 sears riding mower Thanks for any help rcwebster72@hotmail.com Carlton Webster
Go to www.partsdirect.com. This is Sears website for equipment information. Put the model number in and it should find the model you are working on. A diagram should be available there.
Sep 25, 2009 | Craftsman Garden
I have an older 12 Hp. Sears lawn and garden tractor. The 2 wires going to the neutral safety switch are missing. How can I replace these two wires? Where do they tie into the system FROM the switch?
This is usually a positive wire coming out of the ignition switch to the neutral safety switch then from there going out of the switch to the starter solenoid.
Sep 18, 2009 | Garden
Sears lawn tractor 917256491 unable to activate start solenoid.
first see if u can jump the started with a screw driver, also check fuse could be blown. do u have battery voltage? here is a site for a wiring diagram www.managemyhome.com.
Jul 23, 2009 | Garden
Garden Logo
83 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Matt Olenzek
Matt Olenzek
Are you a Sears Garden Expert? Answer questions, earn points and help others
