Question about Toshiba Regza 46RV535U 46 in. LCD HDTV
Very low volume. have to turn up to over 40 to get any kind of volume.
Reset tv to factory defaults and still no improvement
    Top Expert:
  • Toshiba Master
  • 74,136 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Apr 20, 2015
The volume is stuck on 255. I cannot turn the volume down from the tv or remote
Try to make factory reset. There is some step to do it. here added a link from which you can have the institution to do the factory rest. Go to the link and search wit the brand and model number and find the article.
Nov 21, 2015 | Sony Bravia KDL-40S4100 40 in. LCD TV
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
LCD Thomson 32LB040S5It the sound is always in high volume
I assume you have already tried using the buttons on the side of the TV to adjust it? I would just do a factory reset on it. Enter the TV main menu. Select factory reset to return the TV Menu settings to the factory default values. If this does not fix it unplug to TV for 45min to do a complete hard reset.
May 20, 2013 | Televison & Video
Just bought an RCA tv that came from a hotel,model # J27330BL, and trying to reset to factory defaults as it only allows certain channels to be utilized. Also, trying to get reset so I can switch to...
There's no way to reset factory default but can access service menu, Hold down menu button on front panel and press volume up and power at the same time, on the top right screen, use volume up, Press to scroll to 72, press volume up and your are in the service menu.
Aug 20, 2011 | RCA F27442 27" TV
No audio,tried menu items and selections,nothing.The sound just went out,what do you think it might be?
There is no sound or low volume coming from the television speakers.
Solution Follow this procedure to troubleshoot when there is no sound or low volume coming from the television.
NOTE: Because each of these steps represents a possible solution to this issue, check the television status after completing each step.
Increase the volume of the television. Ensure the television audio has not been muted. Ensure no headphones are not connected to the television. If using a set-top box with a volume control, increase the volume of the set-top box.
NOTE: If the set-top box is connected using an Audio/Video (A/V) connection, ensure that the A/V cables are connected securely to the appropriate video input on the television.
Verify that the MTS settings of the television are set to MAIN or STEREO .
NOTE: If the source device is not set to stereo or is not capable of transmitting a stereo signal, sound may come from one speaker on the TV only, and the volume will sound low. In this case, adjust or replace the source device.
If the TV has a Simulated effect in the audio menu, turn it off . Ensure the televisions speakers are not set as the center speaker.
NOTE: Some televisions allow the televisions speakers to act as the center channel speaker when using a multi-channel receiver.
Verify that the speakers are set to ON in the television menu.
IMPORTANT: If the television has audio output jacks and they are connected to a stereo system, then the speakers on the television may be turned off. Some televisions require the internal speakers or the center speaker setting to be off before audio can be sent out to a stereo receiver via the audio out jacks.
Ensure all audio and video cable connections are properly connected to the television.
Test the television using another source like a VCR, DVD player or Blu-ray Disc™ (BD) player.
Reset the television to the original factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
NOTE: If your remote control does not have a RESET button or the procedure did not reset the TV to the factory default settings, perform a power reset.
If the issue is still unresolved after completing all the troubleshooting steps suggested, service may be required.
Jan 30, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
My tv worked fine for two years. I unplugged it, moved it and turned it back on. Its not on mute and the volume is trned on
Tries tv unplug,replug it back like about an hour later.By letting the tv to resetting itself back to the factory setting.Turn it on go into tv menu goto AUDIO setting go down to do resetting,audio are resetting again.The tv should have audio again now.
Dec 17, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Problem on polaroid 04011c not shoving menu display or volume or eny command
Does your set respond to the controls on the set itself?
If you, are you able to access the setup menu to perform a factory reset?
If so, press menu, navigate over to setup, then choose reset defaults, to see if that improves your situation.
I hope that helps.
_________________________________________
Polaroid TLA-04011C Manual Download
Polaroid TLA-04011C Service Manual Download
Apr 26, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Volume really low, even when turned right up
So the speakers and the individual amp channels work so that lets out the obvious big hardware items.
This is starting to sound like an obscure setting was set or changed by mistake.
It would be nice to figure out what that is/was in case it happens again but you may eventually have to resort to resetting the receiver to factory defaults and start over by holding the1/0 button for 5 seconds.
Mar 04, 2010 | Sony STR-DE875 Receiver
I have to have the voume at 30 to get good sound
Try going into the menu and selecting the sound menu and resetting the sound to factory default..If this doesnt help matters you can change the sound preferences to custom settings..As long as the sound isnt distorted at low volume then this solution will apply..If the sound is distorted at low volume then your speakers may be faulty..sometimes caused by listening to the tv at full volume over long term which strains the speakers and prematurely ages them
Oct 17, 2009 | Samsung HP-T5044 50 in. Plasma TV
Toshiba Regza 46RV535U 46 in. LCD HDTV Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
