Question about Bruder MAN TGA Container Service Truck
What is edc code 0094 - Bruder MAN TGA Container Service Truck
My man tga tuck show this on dashboard edc 03779-10 what is the meaning
The following link provides the brief explanation of the error codes. The EDC code reported is likely related to the common rail fuel delivery system. It will likely take specialized equipment to diagnose the problem properly only available at a service center.
Hope this helps?
http://www.techtransa.lt/MAN_klaidu_kodai.pdf
Jul 04, 2016 | Toys
My truck the light EDC its on how to fix
EDC is for electronic diesel control , which i expect you knew , so i would get the OBD codes read to pinpoint the sensor/switch causing the issue , can't be more exact as you faile to mention vehicle make etc
Apr 03, 2015 | Cars & Trucks
Scania v 480
refer to the Scania service department for the code readings interperation as they are specific to Scania codes.
Dec 14, 2013 | Cars & Trucks
Generator code 0094 01
Can you be more specific? what model Kohler is it, Model number KW etc.
Sep 15, 2013 | Kohler Electrical Supplies
I have a problem with my Man Truck TGA 33.360, Its showing alot of error codes on dashboard EDC 00959-01, EDC 00960-01, EDC 00961-01, EDC 00962-01. What could be the problem?
I have an answer for you.The codes are coming from a lost Tachometer memory.Yoour Edc Control Unit and teh Tachometer are not correctly aligned.You need to have th Tachometer reprogrammed.It has lost memory
1.EDC:00959-01 >seconds-Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
3. EDC:00961-01>hour- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
4. EDC:00962-01>Day- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
5. EDC:00963-01>Month- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
6. EDC:00964-01>Year- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
Nov 15, 2012 | Bruder MAN TGA Container Service Truck
GE universal remote codes for RCA XL100 TV
Try these codes
449, 637, 692, 701, 715, 747, 717, 726, 772, 781, 795, 827, 845, 866, 867, 870, 871, 872, 875, 878, 879, 895
0031 0004 0048 0054 0094 0100
0102 0107 0129 0191 0005 0009 0000
0162 0163 0342 0003 0015 0022 0096
Apr 12, 2012 | GE Televison & Video
Internal error mdlcrum 0094 in samsung printer ml-2550
I HAVE A PRINTER SAMSUNG ML 2550 ERROR CODE MDLCRUM 0094
Mar 27, 2009 | Samsung ML-2550 Laser Printer
Frigidaire cplef398ccb Flashing F7
version 1 of your unit F7 error code.
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
This does not mean that this is the problem but it is where I would start. EDC is less than a fouth the cost of the EOC.
Please take the time to rate this solution
Thanks,
clarkco
Feb 01, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Code F9
Lock motor relay watchdog is active when it should be off Microprocessor checking the operation of the EDC lock relay after self clean is selected, relay failed. Replace EDC.
Dec 15, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Bruder MAN TGA  Container Service Truck Logo
74 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
