Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
A
Anonymous Posted on Apr 20, 2015
What does FSP1 mean - Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Bill
Level 1:
New Friend:
  • Contributor 39 Answers
  • Posted on Apr 29, 2015
Bill
Contributor
Level 1:
New Friend:
Answers
39
Questions
0
Helped
15888
Points
67
On my stove the, a few years old, I had two problems..
"F1" - which showed after a minute of power. The clock didn't work but manual element and oven controls would. Basically the circuit board would not switch to 'digital'. After I checked the board components and seeing none were burned- I resoldered all the components except the chips( to rule out a 'cold' joint and replaced the largest capacitor near the display with a new capacitor of the same value but a higher voltage. PROBLEM SOLVED,
F5-E1 was supposed to be a problem with the door lock when self cleaning is used. I checked and cleaned the latch circuit from the door at the same time as the timer board was checked... all troubles had cleared. I never had the "P1" display you speak of.
Cold solder joints and worn out or degraded value capacitors from the heat have been a large majority of the issues I've seen to date when obvious burned circuits or relays are not the issue.
2answers
I lost my manual for Snappy Chef. I do not know if E06 appear what does it mean.
LOOK UP ON LINE TYPE IN E06 OWNERS MANUAL OR E06 PARTS MANUAL MAYBE ONE OF THOSE WILL SHOW YOU WHAT IT MEANS THE E USUALY STANDS FOR ERROR. THE 6 COULD MEAN THE OVEN OR BROILER OR A CENCER.
Feb 02, 2015 • Ovens
I have a kenmore elite oven what does an error code F-3 mean
Th eF3 error code means that their is a problem with the tempature sensor...this tip i wrote expalins what the F3 error code means.
http://www1.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
2helpful
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
1helpful
2answers
What does the oven control pictures on the control mean , picture of fan understood,
what do the pictures mean on the dial indicator on a eurotec oven mean?
Dec 16, 2010 • Ovens
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
Says f1
F1 error code usually means that the oven temperature has exceeded 590 degrees. Usually this means that the oven temperature contol sensor ( or thermostat) has failed allowing the heating element to overheat the oven.
To correct this you will need to fit a new sensor. Sometimes the error code can mean a temporary glitch which may be cured by turning off the power for 30 mins and then resetting but if the problem persists then a new sensor is the answer.
4helpful
2answers
What does e1 f3 fault code on my oven mean
F3 means your oven temperature sensor is open. you will need to get it replaced. hope this helps.
17helpful
3answers
Maytag oven says sabBATH what does it mean?
My Maytag oven also has a "Sabbath" mode and you can check your manual to see how to turn it on/off. I have a different model than yours, but to turn the "Sabbath" mode off on mine, the manual says to press and hold the CLOCK pad/button for five seconds.
3answers
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
