Question about Frigidaire Dryers
Dryer not heating
My dryer is not heating but everything else seems to work. Should I assume it's the heating element? Are there other parts I should check?
    Scholar:
    New Friend:
  • 123 Answers
The issue, your heating circuit inside the dryer is not getting power.
1. Can be heating element
2. Can be a safety switch such as thermal fuse, high limit thermostat, Thermal cut off
3. Can be temperature sensor thermistor or even main control thermostat.
4. Can be your Control board not giving power to the heating cycle
Posted on Apr 25, 2015
  • Official Brand Answer
  • 2,267 Answers
Thank you for your inquiry, friend!
Based off the information you have provided your Frigidaire dryer is not heating. This could be a potential issue with your heating element, timer, or thermostat. In order to accurately check each part you would need to disassemble your dryer and test each piece for the proper continuity. This is not a simple DIY job and I would highly suggest contacting a professional technician comes out for proper diagnosis and repair. Best of luck! -Matt
Posted on Apr 22, 2015
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 33 Answers
SOURCE: Frigidaire Gas Dryer not heating up. Other elements are all ok.
It sounds like your igniter is no good. At all costs, check the Fuse before anything else. It is usually accessed from the back of the unit.
Posted on Nov 25, 2008
MNTECH
  • 1543 Answers
SOURCE: LG DLG2524W DRYER WORKS FINE EXCEPT DOESN'T HEAT UP
1. Open dryer door and remove the phillips head screws at the 5 and 7 O'Clock positions. 2. Remove three screws at very back, allowing top cover to be moved back about an inch and lifted off. 3. remove screw at top left and top right from front top panel. 4. pull plastic front panel along top edge to release front top panel. (watch for sharp edges) 5. Swing top up and over onto top of dryer. 6. Unplug light and door switch. 7. remove four screws at top of large lower panel. 8. lift panel up a bit and off. 9. unplug sensor plug at bottom allowing panel with door to be set aside. 10. gas dryer has dime sized high limit thermostat on left front side of burner chamber. Has two wires on it, with a small pin in the center. Push the pin in. Reassemble and clean out vent, eliminating flexible venting, replacing with rigid aluminum piping and elbows. Outside vent should have a four inch vent flap opening, not just a two inch if it is that style.
Posted on Jan 03, 2009
Testimonial: "YOU HIT THE NAIL ON THE HEAD WITH THIS SOLUTION. THANKS"
  • 686 Answers
SOURCE: MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Posted on Feb 27, 2009
SOURCE: WHERE DO I FIND THE HEATING ELEMENT ON A ESTATE DRYER
i have a estate dryer it blows hot air and drum turns but does not dry the clothes so it takes 3-4 rounds to dry the clothes what cold be the promblem
Posted on Mar 17, 2009
Model LEQ9508PW1. It has stopped getting hot. Just stopped putting out any heat. I assume that it is probably the heating element that has gone out. Is there anything else I should check first before...
Check first the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
Also bypass the cycling thermostat if the dryer still doesn't heat up with the thermal cut-off (cut-out) and the high-limit thermostat both bypassed. If the dryer still doesn't heat up, take the heating element out and inspect it for damage. Replace the heating element if damaged.
Jan 18, 2011 | Whirlpool Dryers
Heating element inop no heat to dryer everything else seems tobe working where can i buy part and where is located in dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 16, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
No heat
Assuming it is tumbling, check out the heater element. This is the most common problem for this type of dryer.
Jan 02, 2010 | LG DLE2532W Electric Dryer
Not heating
Hi, Check the thermostats and the fuse. Make sure the 4" vent to the outsideis cleaned. If it is plugged, it will cause elements and thermostats to go bad.
The thermostats and the fuse must have continuity. If they are open, replace them. All these parts are located in back on blower housing and element housing.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Kenmore 80's series dryer
Dryers could not be simpler devices. I assume that since all you mention is that the dryer is not heating, everything else on the dryer is working as normal. ie. You could put in wet clothes, set the timer start the dryer and the drum starts turning and air comes out of the exhaust. It just happens not to be hot. I am also assuming that you know how to use the drier and that it is not set on tumble (no heat).
If that is the case, the heating element is almost certainly burned out. Basically this is the part of the dryer that glows red (just like an electric stove) when electricity passes through it. Unplug the dryer and see how it can be taken apart. Many open from the top or the back. They are all slightly different. The heating element will be located near the blower fan typically at the bottom of the dryer. Figure out how to get at this, pull the old element out and then replace it with your new one. There will be two electrical connections. You may even see where the element just slides into position by the blower and can be removed with a couple of screws.
You should only need a screw driver to do all of this.
Plug the dryer in and enjoy the warmth.
Sep 22, 2008 | Kenmore 659 Electric Dryer
IS60VS Dryer not heating
Sep 19, 2008 | Dryers
Kenmore Dryer
If you go to searspartsdirect.com, type in your model number in the Search menu, then look under the "Bulkhead" menu option, you will see an illustration of your dryer. You will need to remove the heater box cover (item #5) to get to the heating element. The element should slide out of the bottom of the heater box housing. Removing the housing from the dryer first makes it easier. Sometimes you may need a little muscle in getting the heater coil to come out.
Have you checked the thermal cut-out(TCO)/hi limit thermostat? This is item #1 in the drawing. If your dryer runs, but does not heat, this is normally the culprit. You are right to assume you could have a heating element problem, but the element tends to be more resilient. In my experience with electric dryers, the thermal cut-out tends to go bad first. It's easier to check and easier to replace as it is mounted on the outside of the heater box. Check for the following:
With the heater box STILL installed, the TCO will be a small component mounted at the top of the heater box housing. The hi-limit thermostat will be mounted at the bottom of the heater box housing next to the ceramic terminal of the heating element. With the dryer UNPLUGGED, disconnect the wires to the TCO and do a resistance reading. It should read 0 ohms if good. Do the same with the hi-limit thermostat. It should also read 0 ohms if good. Last of all perform a reading across the leads of the heating element with the wires unplugged. You should get a reading of 9 - 13 ohms if it is good. If you determine the TCO or hi-limit thermostat to be bad, it is HIGHLY recommended that you replace them BOTH at the same time. They are sold as a set (part #279769). Failure to replace both components could result in part failure. The part number for the heating element is 4391960. I hope this helps you.
Mar 17, 2008 | Kenmore 63942 Dryer
Dryers Logo
97 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
