Question about Philips GOGEAR Audio Players & Recorders
MY GO GEAR MP3 PLAYER WILL NOT TURN ON AFTER A CHARGE
CHARGE PORT NOT HELPING
ThaMp3Doctor
  • 8596 Answers
SOURCE: Samsung MP3 not charging
Get the driver from:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=&dType=D&vType=L&mType=&model_cd=&menu=guides&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-K3JAB&isEqualsY=Y#
Posted on Jul 05, 2008
  • 37 Answers
SOURCE: mp3 insignia sport
is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
if no hub try a different usb port or a different cable
Posted on Aug 24, 2008
SOURCE: mp3 player wont charge or turn on
i have the vl 868 and it would only turn on with the charger in- not when it was unplugged. it took me awhile- you have to turn the switch on and then hold play for like 4-5 seconds for it to turn on.
Posted on Apr 21, 2009
SOURCE: My Philips Go Gear SA3025/37 MP3 player won't charge/turn on
i had the same problem. my reset button was jammed. the problem: the reset button is so deep in the tiny hole its hard to tell if you even really hit it when you put a pen in there and somethign like a sharpened pencil just doesn't go deep enough. i monkeyed around wiht a peice of straw in the reset hole for about 10 seconds then tried to turn it on and it worked. good luck
Posted on Aug 10, 2009
Messic
  • 94 Answers
SOURCE: My samsung YP-U4 mp3 player
Download the latest driver software from the Samsung website with the link below and install it on your PC. Click on downloads > Software.
If that doesn't fix the problem, try connecting it to other USB ports as the one you tried could be faulty or some USB ports do not provide enough power for the device to get connected.
http://www.samsung.com/my/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=&prd_mdl_cd=YP-U4AB/XME&prd_mdl_name=YP-U4AB&srchword=YP-U4
Posted on Mar 04, 2011
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
I can't get mines to charge correctly, can you help me?
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Apr 25, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
I have the philips go gear hdd1830 and it wont turn on. I tried to connect it to my computer and it does not show that it is connected to the computer and no charge as well.
Hi it sounds like the onboard battery is flat, so will not swich on. You have also stated the player is not recognized by the PC and not charging.
Try another USB lead and also try another USB port, either of these could be at fault.
Apr 17, 2010 | Philips GoGear HDD1830 MP3 Player
How to charge My Mp3Player
Hi giannuandi,
Plug it into a USB port, and it should charge by itself. Use the USB cord Apple supplied for transferring data.
Dec 05, 2009 | Apple iPod shuffle MP3 Player
My mp3 go gear wont charge, i've tried to charge it on the ubs port and i've tried to synx it again and nothing is charging it
try getting an old usb phone charger and using that if that wont work then your battery may be dead and its time for a new one
Sep 20, 2009 | Philips PSS110/17 MP3 Player
Please Help
Hello Pookie34,
In general, most MP3 players are charged by connecting them to the USB port on your computer using the supplied programming cable. Make sure you are connecting the cable to a USB port on the computer itself and not a USB hub as most USB hubs do not have enough output power to charge your device.
Your MP3 player can also probably be charged by connecting it to an appropriate AC wall charger or automobile power cable. However, for most manufacturers these are optional accessories not normally included with the player.
Best Regards.
Ken
"Go Ahead. Use Us."
Jul 22, 2008 | Memorex MMP8565 MP3 Player
I need to charge my RCA TH1101 Mp3 player Help!!!!!!!!
simple. The Pearl Series for RCA is AAA battery powered. You cannot charge it through your USB port.
Jul 15, 2008 | RCA TH1101 MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
hii
just re plug it and see what happens or.. if you have wall mount charger with a usb connect .. then us it ... and if all fails... open ur player and disconnect the batter for a minute and reconnect it and then put it to recharge...
let me know what happnes..
tc
May 28, 2008 | SanDisk Sansa MP3 Player
Go Gear MP3 player won't come on
mine too, i charged it all night and in the morning it wont turn on, stops on philips logo, anybody help us plz!
Apr 12, 2008 | Audio Players & Recorders
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
