If my password to my router say's Failed how do I log into this or change password?
For some reason went I try to log into my modem it says that log in has failed. Not sure if I may have forgotten my password and need to know how to reset this or whether there's another way to get access? I'm looking to change my password for my modem.
  • 3,960 Answers
You just need to reset the modem/router. On the back, you should see a small push button. With power on Press for 30 seconds, and then release. Wait for the router to reset. You can then enter the device, using the baseline URL (normally 192.168.1.1, but others vary with the device). You will need to use the admin name and password defaults (you can find these on the internet by searching for them), and then you can interact with the program on the device.
Posted on Apr 20, 2015
Can't log into 192.168.0.1
The article I read suggested 192.168.100.1
admin (no capitals)
motorola (no capitals)
And no need to get your breathing rates high in case you have changed the username/ password of Motorola SBG900 and forgot them, as you can just reset the Motorola SBG900 router by press-and-hold the reset button with a straightened paperclip for about 15 seconds.
http://modemly.com/Motorola-SBG900-router-setup
Feb 15, 2018 | Arris SURFboard SBG900 Wireless Router...
All lights of the modem are on but there is no internet connection although I reset the modem, turned off everything and unplugged and waited for 6 minutes. Besides, I went to the 192......., put the dsl...
1. Call DSL provider verify service is active. They should be able to ping their DSL modem.
2. If good service, plug your pc directly into dsl modem. If youre able to connect, then the router is bad. Youll need a new one.
3. If I read this wrong, and its the dsl modem that is not connecting, AND the service says its working, then it maybe the dsl network port has failed. In which case report it to your service provider and they should replace the unit for you.
4. You can try to unplug and replug the network cables, all of them. Or try different ones. Its just possible you are getting a poor connection at the wire terminator.
May 24, 2011 | Computers & Internet
Forgot the password to log in to make changes. I have a surfboard motorola modem. I tried hitting the button on the back of the modem. It reset the settings but not the password. please help.
Are you trying to reset the cable-modem, or the wireless router?
Take a Norwegian paper-clip, and straighten one end.
Turn the router off.
Push the end of the paper-clip into the small hole in the back of the router,
and hold it in for 30 seconds. This should reset the router.
Dec 14, 2010 | Computers & Internet
Setup for Netgear N150 Wireless Router WNR1000 requires log in.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 26, 2010 | Computers & Internet
When I change modems i can't connect to the internet.
You must provide valid wan configuration on the modem part. Get it configured from your providor or check your old modem configuration note down wan settings. Apply these settings to your new ADSL+Router.
Jul 15, 2009 | Computers & Internet
Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
Jun 08, 2009 | Arris SURFboard SB5101 Cable Modem
Can't get it configured
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
May 26, 2009 | Buffalo Technology AirStation G54...
IPod connection to Zoom ADSL X65590 router
you have to log in http://10.0.0.2 at the button/under of your router tells you the generic name and password you need to enter, just follow the instructions, you'll be able to change your settings
Dec 26, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
I've forgotten the password?
if you have changed the password the only way is to reset the router
there must be a little button on the back or bottom which you can push with a pin, press that and admin/zoom works again
Dec 02, 2007 | Actiontec GT704WG Wireless Router...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
