Question about Ariens Garden
Ariens EZR 1742 blades slow up and bog down engine while cutting. All new pulleys and belts and blades. Idler pulleys are new.
  • Ariens Master
  • 2,475 Answers
Your blades are dull or going to fast
Posted on Apr 20, 2015
    Problem Solver:
  • 17 Answers
Agree with dull blades try to sharpen the blades as well as if it is really high grass try bringing the deck up a notch
When turning on pto blows the fuse
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
Aug 03, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
I have a model LTH130 42 inch cut mower and just installed a new elect. clutch and started mowing grass and it began to feel like it was bogging down and I stopped the engine and the belt was very hot....
Hi and welcome to FixYa, I am Kelly
See this link and locate your deck:
http://opebycrigby.tripod.com/decks/jddeck.html
Make sure you have the belt routed correctly. ALSO make sure that you do not have it flipped 180 deg over the idler.
I recommend that you unhook the belt from the mower deck pulleys and try rotating the blades. A bad blade bearing can cause a belt to heat up. Of any of the blades are hard to turn by hand that blade bearing will need to be replaced. Check the idler pulley also.
If after checking the above you continue to experience a problem just respond here and I will help you.
Thanks for choosing FixYa,
Kelly
May 25, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I turn on the mower switch and the motor bogs but the blades do not turn
Since it bogs down, your PTO clutch is engaging, but something driven by the mower belt is stuck. Turn it off and look for simple things first: look under the mower deck for a branch or object jammed in there, or a bent blade. If that's all ok, then take off the mower belt and spin each of the spindles (the pulleys that drive the blades) and also the idler pulleys. If one if stuck or binding badly, you have found the problem. Idler pulley bearing are inexpensive, but spindles are spendy. Good luck! Please rate my solution if helpful, thanks.
Jul 28, 2010 | Craftsman GT 5000 26 HP54" Garden Tractor...
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Looking for manual Arien EZR 1742
Go here:
http://www.ariens.com/corporate/pages/partsradar.aspx
Hope this helps
Jun 10, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
142 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
