Question about Engel Refrigerators
Why does my engel MT45F-U1 fridge and freezer vibrate and make so much noise?
This portable refrigerator/freezer runs VERY loud and vibrates - how can I fix the problem?
  • Engel Master
  • 5,323 Answers
Have u checked the groumets on the compressor? more than like are bad
Posted on Apr 22, 2015
ENGEL STILL GETS COLD BUT RUNS VERY HOT AND USES MORE POWER
FRIDGE COILS SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 27, 2015 | Engel MT-35F-U1 34 Qt Portable...
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Vibrating and noisy when running. the vibration varies along with the noise. When tilted noise stop, motor still running. Any ideas on problem?
Your motor mounts may be dried out and hard. Try prying the compress up a bit while it is running to see if the noise subsides, if so you can replace the mounts or put some kind of rubber under the compressor to absorb the vibes.
Feb 23, 2011 | Engel MT-35F-U1 34 Qt Portable...
Long running periods with Engel B 12v fridge
the owners manual will tell you but yes most do
Apr 11, 2010 | Engel Freezer MT 27F-U1
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 20, 2009 | Refrigerators
Blower fan in the freezer is making a vibrating
only if the fan noise is driving you crazy. the noise is probaly the motor starting to go out. you can replace it. it might save you money in the long run to replace it, if it goes out you could run into bad food in your fridge.
Jun 26, 2009 | GE GSS20IEM Side by Side Refrigerator
Water pooling in base of fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Engel 43 Qt.Portable Freezer.
Refrigerators Logo
160 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
