Question about Kitchen Ranges
F11 error persists after powering down and back up. Model 79047783403. Does the EOC need to be replaced and can I do this myself?
  • Kitchen Ranges Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service appliance technician.
The error code generally indicates either you have a bad oven thermocouple or the EOC is bad.
First, remove the thermocouple through the back.
F11 error persists after powering down and back up - 25656710-5ds3gtdzu2lsmxhybqelrkoe-4-0.jpg Part #: 316217002 Cost: $32.00
With a multi-meter set the meter to the lowest Ohms. Insert the two probes into the two contactors. You should get a reading between 1000 - 1100 Ohms if it is good.
If this is good then you have a bad EOC board.
25656710-5ds3gtdzu2lsmxhybqelrkoe-4-2.jpg Part #: 316418554 Cost: $190.00
When replacing make sure you ground yourself by rubbing your hands on bare metal. Static electricity will knock out a control board.
The part cost is based on Sears cost. Search the internet for the part numbers, you can get these parts for less.
Posted on Apr 28, 2015
  • Peter Goodwin
    Peter Goodwin Apr 28, 2015
    Peter Goodwin, Glen Burnie, MD, 443-306-1362
F11 error code
Thank you for your post, Friend.
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree. - Z
Aug 13, 2014 | Frigidaire FGB24S5A Gas Single Oven
I AM GETTING F1 ERROR CODE ON FRIDIGEAIRE MODEL #CFEF372CS2 SERIAL # NF41924422, ONLY OVEN NOT WORKING
I am 99% positive you need a new EOC based on the fact that you said you heard the all too common pop noise. EOCs usually cost around $200-$300 and sometimes more. The EOC in this is the same as your clock, if you took off the top back you will see burn marks on the back of the clock.
Jul 04, 2014 | Frigidaire PLEF398AC Electric Kitchen...
F11 ault code. what does that mean?
Hello Polly, this is Z. I am happy to assist you!
Mar 19, 2014 | Frigidaire Kitchen Ranges
My frigidare oven shows f11
Hello Jaime, I am happy to assist you!
Typically error code F11 on your Frigidaire appliance indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Best regards!
Feb 05, 2014 | Frigidaire Ovens
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
Dec 13, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Frigidaire f11 error
I suggest to try unplugging the device from power socket 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Failure Code: F10 / F11 / F12 / F13
Condition:
- Runaway Temperature.
- Shorted Keypad.
- Bad Micro Identification.
- Bad EEPROM Identification/Checksum error.
Check/Repair:
1. (F10 only) Check *RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
2. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
3. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 09, 2011 | Frigidaire Gallery 30" Self-Cleaning...
We are geting a F 11 code on this Model number plgfmz96ecc
Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
F11
Shorted Keypad.
1. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
Jun 13, 2011 | Frigidaire PLES399EC Electric Kitchen...
Kenmore electric range shows a f 10 code when oven is on after while.
F10
1. (F10 only) Check RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
I would first pull your range out from the wall, unplug your range, then take off the back access panel and using a DVM check the ohm reading on your oven sensor#37 here:
http://c.searspartsdirect.com/lis_pn...9098-00003.png
It should ohm out at 1100 ohms at room temperature.
Here's the oven sensor probe for your model:
Part#316217001
show?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfmtawnzeynjezl0ldvy9zb3rvahb0cmfwlw%3d%3d
If that checks good, then your EOC control board is the problem.
Here's the EOC Board for your model:
EOC Board - Manufacturer's Number: 316418207
I hope that this helps.
asnowman
Mar 05, 2011 | Kenmore 95592 / 95594 / 95595 / 95599...
What is the EOC and how much does it cost to replace? Can I replace it myself or do I need a professional to replace it?
kenmore stove model #c970635326 serial #nf70205945 is showing f11 on the clock and a constant beeping noise.
when you unplug and plug it back on the clock show 12:00 for a few seconds then the f11 shows again and the continuing beeping noise
how much is an eoc to replace....can i do it myself....
Jan 09, 2011 | Kenmore Ovens
Kitchen Ranges Logo
136 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
