Blows the trip after a while - Audio Players & Recorders
    Sergeant:
  • 402 Answers
Possible too much of load from speakers check your resistance
Posted on May 05, 2015
  • Audio Player... Master
  • 5,113 Answers
Tricky one! But possibly a faulty output transistors that gets too hot and causes an overload. Or another semiconductor type device in the power supply doing the same.
Posted on May 04, 2015
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Tempstar 2400 blows the a/c breaker when heat is on
How long before the breaker trips?,does the a/c work ok,gas heat or heat pump?,electric strip heat on auxiliary heat,if these are shorted they will trip a breaker,if the breaker trips instantly you have a dead short in the system,if it runs for a while it may be a weak breaker,you may have a bad compressor if it trips fast or a shorted out heat strip,need more info!
Mar 08, 2013 | Heating & Cooling
Firenzi blows trip after 1 min
this could be your door switch
Oct 19, 2012 | Washing Machines
Duo therm a/c turns on blows cold after a few minutes it trips breaker on the power source
Take off the to the compressor it sounds like a burned terminal is causing the breaker to trip
Jul 26, 2012 | Dometic Rooftop RV Air Conditioner
Rv airconditioner trips breaker
Does it trip when fan only , or when compressor for cool cuts in? Sounds like capacitor perhaps . Get back to me with model number, and whether it's a ducted system, or blows out at ceiling assembly.
Apr 02, 2012 | Dometic Rooftop RV Air Conditioner
Hi, i have a hotpoint WD860 washer/dryer and when it is turned on will blow the trip for the house mains, i have found today though that if the door is open it will not blow the trip, any ideas please
reason the machine blows trip probly damaged wire unplug mach remove lid and check wires around dryer unit this is often the scource good luck
Jun 08, 2011 | Washing Machines
Horn blows fuses
Don't bypass the fuse, you'v either got a short in the horn or the wrong fuse
it takes a 20 amp and I highly ecommend using a plug in breakr instead of a fuse
Put in a breaker, if it trips unplug the horn and try again, if the breaker trips again, there's a pinched wire, if it does NOT trip replace the horn itself
Sep 13, 2009 | 1997 Chevrolet S-10 Pickup
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Oven fuse blows - Nothing works
try lifting the stove top assy and checking wires under main top, leading to the elements them selves??? if tis tripping and not allowing to reset its gotta be an obvious short. isit hard wired directly to stove or into a 220 cord and plug???id look again, perhaps remove entire back panel and have someone trip on the breaker you might see where it flashes as it trips off
Apr 03, 2008 | Tappan TEF242 Electric Kitchen Range
Indesit D61D tripping RCD
the heater is faulty(shorted) and check that the hot water is getting to the appliance as the buzzing is the soliniod being powered but the water is not passing through
Aug 15, 2006 | Maytag 24 in. MDB8600AW Jetclean II...
229 people viewed this question
 Grubhead
Grubhead
